Hi.
I have attached a raster to bentley inroads and created my horizontal geometry and edge of pavement as per online video training.
the training video for defining vertical geometry from PI at 4:45 says you need to "set active terrain". otherwise the vertical geometry "view 2" doesnt load.
the training video loaded up an already created terrain file. I dont have one and have to make one i think, from scratch.
I am not sure how to do this, or get around this, can anyone help ? thanks.
Sure, if you have data for a terrain model follow this:
communities.bentley.com/.../7039.aspx
Frank
