I want to map the "XS Navigate" buttons to F1-F5.
Can anyone help?
this dialog is from geopak active chain control
sorry can't be done
Practically there isn't. You could maybe use VBA (if you know programing) but the amount of work/effort won't justify it. Plus, I am not sure that there is a command in VBA that allows you to navigate xs.
Nico,
How about having active chain control auto-sync with xs navigator?
communities.bentley.com/.../96814.aspx
no, sorry those are two independent tools.. what is it that you are trying to do?
I am trying to navigate through cross sections using the "Active Chain Control" quicker than havingto click the "VCR" type buttons with the mouse
if you use the regular xs navigator, you can just select the station you want to go to.
if you use active chain control, just navigate your plan or profile view and the x sections will update very fast.
