I have a few users working on a legacy project that continue to suffer from having user prefs wiped in Geopak 2004 8.8. User just got a new laptop and issue has migrated with him. Other user in the project are fine. Fresh rsc files and upf. Different Windows 7 profile gets same result. User has full permissions to the Bin folder. Each time he fills in the info and renters V8 2004 the gprefer.rsc reduces to 1kb and the geopak.rpt show default info. Proj manager currently being used as a workaround but issue is still perplexing.
Sorry, I know its an old version but help is appreciated.
Mike
The only suggestion I have is to make sure there are no GEOPAK resource files in the Working Directory along with the BIN folder. Then go thru the process step by step setting the user prefs and then exiting and coming back in to check. The program reads the resource file to fill out the dialog so there is not many variables here.
Beebe, if the Working directory is not being filled in what would the default location to look for?
The default location is where the dgn file resides
