Hi
I am creating Field Book in PowerCivil for Denmark SS3 and it ask me to open GEOPAK SMD ('XML) file, but I cant´t find one and what is it for?
regards
Sigfús
This dialog is the "Select Linked Feature Definition Style File" and it is asking the user to browse to the style file that was used to link the Survey Features Definitions currently stored in the DGN file. This style file is the XML file for GEOPAK users, or the XIN for InRoads users. You can select the drop-down arrow next to the file type to select the GEOPAK XML, InRoads XIN or MX PSS file. You can also avoid this dialog by setting the "CIVIL_SURVEY_STYLEFILE " configuration variable to point to the XIN/XML/PSS file.
Can I then use the same .xin file that is linked to my native InRoads?
/ SigfĂşs
Search the threads for InRoads Survey discussions - there are a number of them about issues that InRoads users will encounter in processing a fieldbook in OpenRoads. One of the more critical is the setting that specifies the Alpha Code must appear before the linking codes (control codes) and it is also necessary to specify the characters to be used as linking codes - the defaults may not match InRoads.
For some reason, when using the linked XIN file, it does not use it to read the control codes to use.
The last thing is a configuration variable that specifies that spaces are required between alpha codes and linking codes. Otherwise, if you have alpha codes that begin with the same characters as some of your linking codes, the software reads the initial characters as some type of linking code and then reads the remaining characters as some type of alpha code - which usually results in it treating them as unknown codes.
Answer Verified By: Sigfus Jonsson
