Geopak SS3 Open Roads Target Aliasing issue
I have an issue with a corridor that is targeting a retaining wall.  Basically the end condition is not finding the retaining wall.  This issue does not exist in the version .493 but does exist in the new MR .674.
In the version .493 you can see by the screen shots below the corridor is using target aliasing and it is finding the retaining wall.
I have the target aliasing set as such..
In the MR version .674 you can see by the screen shots below the corridor is using target aliasing and it is not finding the retaining wall.
The end condtions are set so that it will find the active surface.  Like I mentioned above this currently works in ver. 493 but not in ver. 674.
Geopak - 08.11.09.493 and 08.11.09.674
MicroStation - 08.11.09.459 and 08.11.09.578
Win 7
TIA
Sean
Edit Post:
Ok, so if I open the file I created in ver. 493 with ver. 674 the corridor looks correct but if I just reprocess the corridor problem exists.  If I open the file created in ver. 674 with ver. 493 the corridor looks incorrect and if I just reprocess the corridor the problem goes away.
Parents Reply Children
