I am trying to label my XS's and I receive the following error. Can someone tell me how to fix this?
this is what popped up in the debug tool.
try this first
communities.bentley.com/.../271180.aspx
How can I send it to you off line?
Nico, deleting the directory under C:\Users\ yourusername \AppData\Local\Bentley\MicroStation\8.11 did not work.
the other thing I noticed is that your xs are too close together vertically. this can cause issues. can you recut the xs at the standard 500 feet distance vertically?
Could there potentially be a cross section in the design file from a chain that no longer exist in the dgn file. This was a problem in Select Series 2. Cutting the cross sections in a fresh DGN file may resolve the issue.
communities.bentley.com/.../15083.runtime-error-91-when-running-cross-section-labeler.aspx
OK, still not working. Here is what I have done so far.
1. I created a brand new file
2. I displayed the new cross sections at a vertical (AND horizontal just to be sure) at 500' spacing.
3. All chains exist in the GPK.
4. I even loaded the updated xsLabeler.mvba file.
5. I checked to see if GEOPAK is mysteriously dumping .rsc files into the project directory which they are not.
The only thing I have not done is delete all my .rsc files on my C: drive (because I don't want to lose all of my settings).
it opens fine for me. can you send me the new dgn?
do you have other cross sections referenced to this dgn? if so, remove the references and try again
I have nothing referenced. Does having the pattern lines in the same file as the XSEC's matter?
Dale,
it works fine for me with your new dgn as well. try this, copy the dgn and the gpk in your c temp folder.
open the dgn and try open the labeler (make sure that the gpk in use is the one in the c temp)
if this doesn't work, you have an install issue.
