Power Inroads SS3 Workspaces in Projectwise
I have a project running within Projectwise that has been built in PIR SS3. When I fire up the DGN within PW it automatically loads the Bentley Civil Metric workspace (through \examples). Even if the the last DGN I opened outside of PW is opened with my custom workspace, it still reverts to the Bentley Civil one. What is the best way to use another workspace or select one when opening a DGN file within PW.
Thanks, Dan
  • In my testing, the last workspace that I loaded outside of PW is the one that loads when I launch inside PW (without a managed workspace).  It appears that if you delete your PowerInRoads preferences in "C:\Users\user.name\AppData\Local\Bentley\PowerInRoads\8.11 it will revert back to the default "Untitled" workspace.
    You can specify a local workspace to load by creating and assigning Workspace Profiles.  These allow you specify which local workspaces to use when a DGN file is launched.
