Can a code and linking code be separate?
I have noticed that an alpha code used by the field guys doesn't plot in Open roads,  the code is "MISCPT", but is read as MI SC PT because of linking codes with that coding. I hope this isn't too confusing, has anybody ran into this problem? or maybe have an answer?
Thank You
