I am learning Geopak V8i SS2 using the Create Horizontal Alignments Learning Path and the help file as it applies.
I want to create the grid view for my profile and sections. Presently all I see is the base axis and elevation axis. Is there a way to generate the grid or is this a separate cell attachment?
There is no built in tool to draw a grid on your profile cell. There is a macro that comes with the product that you can use to generate a grid. i believe it is addressed in the help or one of the tutorials.
Neil Wilson (aka Neilw)
Power Civil v8i 08.11.07.245
AutoCAD Civil 3D 2018
Is the "Plan/Profile Sheet Composition" and the "Cross Section Sheet Composition" supposed to create the sheets and place the grid cells as required?
Those tools are designed to work with the grids being part of the sheets. The profile and cross sections cells are aligned with the grids on the sheets.
do you want to create sheets, or just place grids? if you just want grids, there are vba's out there that will do that
If I need to do both grids and sheets; I use the vba to generate the grids and the "Plan/Profile Sheet Composition" and the "Cross Section Sheet Composition" to create my sheets?
