End Area Volume Report Not Opening - SS3
I am trying to run an end area volume calculation on a set of cross sections in SS3.  The command recognizes all the corridors in the sections and the existing grounds.  The command runs and appears to do the calcualtion but the report browser never opens with the report displayed.  The toggle is checked for create XML report.
Has anyone else had an issue with this before?  Is there a way to fix the problem without having to recut all the sections and/or create a new file?
Marc
SS3 674
  • Please try resetting the default locations of the InRoads dialog boxes:
    1. Close InRoads/MicroStation.
    2. Open the Window Registry Editor by typing in "regedit" in the search field of the Window Start Menu.
    3. Open the program regedit.exe.
    4. In the Registry Editor, navigate to the following location:
      HKEY_CURRENT_USER\Software\Bentley\InRoadsGroup\Applications\<Version Number>\DialogPos
    5. Right click on the Folder "DialogPos" and select Delete.
    6. Click Yes when asked to Confirm Key Delete.
    7. Close the Registry Editor and relaunch InRoads.
Reply
