How can you view 3D elements in the profile view for OpenRoads?
What I'm trying to accomplish is when we create our profiles, we need to know where cross drainage features are and their size/height, etc. etc. With the Geopak Classic method, this isn't an issue because you draw the culverts into the design model normally and draw your profile around this. However, with the dynamic nature of OpenRoads this isn't as clear cut. If I draw a 3D box for a culvert, the culvert is shown in the cross section view as expected (and hoped), however, it isn't displayed in the profile. How can we reference information into the profile for designing the profiles?
Hi Ken,
Can you just use the vertical geometry tools to project the sheet piling wall levels to your profile using 0 vertical offset or crossfall? This would also dynamically update on change.
Mark
OpenRoads Designer 2022 R3 (10.12) | Microstation 2023.1 | ProjectWise CE 3.4
Thanks, Mark, but I'm not sure what you mean by that. I have a referenced model of the wall (all 3D solids) that I'd like to project into the profile of the wall alignment. I can do a 3D Cut into the profile window, but not sure what you mean by "projecting the wall levels." Any further guidance here? Thanks in advance!
You can extend the Profile 3d Cut function to display elements in front or behind the alignment by going to the Profiles 3d model reference in the reference dialog (created with the 3d cut function), right click and go to "Presentation". In the Presentation dialog that opens, enable the Forward and Back options under Clip Volume settings and then when you reresh your 3d cut you will see everything in your 3d model in front or behind the alignment.
Thanks, Mark.
I did (sort of) figure that part out, but not sure how to set the amount of depth. I can do this in section cuts (set forward and back depth), but for profiles it seems to be either all clipped or not clipped (which shows everything in front of/behind the alignment, but I only want to show a certain "depth" front/back of the alignment, say 1 foot or snapping to the front/back edges of elements.
I'll keep exploring and learning, and I truly appreciate the pointers. Thanks much!
Ken
Yeah I can't figure out the depth side of things either - an enhancement to allow us to specify a forward/back depth would be great!
