Hi, all.
I have been using batch process a lot in earlier versions, but with SS3 (with or without InRoads loaded) I get lots of junk text after my string.
These are the first program lines of my batch script:
place text"A"xy=455705,6818040place text"B"xy=455712,6818047place text"C"xy=455730,6818047place text"D"xy=455712,6818033place text"E"xy=455730,6818033place text"F"xy=455671,6817992place text"G"xy=455664,6817994place text"H"xy=455659,6817999
A-E is placed as expected. The rest is appended with with this text "CIVILCOORD RestoreCoordLockOverridesCIVILCOORD RestoreCoordLockOverrides".
Does anyone have a clue what I am doing wrong?
The output from the batch process is attached to this post.
Any help is appreciated
-Thomas-
I am almost able to reproduce your problem, and I would like to make sure I am able to do so before I log a defect. Can you please view the attached video and let me know if your workflow differs from mine in any way? Thanks.
https://bentley.sharefile.com/d/s2ee41df007c4501b
Thanks, Jaquelyn.
Your workflow looks quite similar to mine, although I use the Utilities→Batch Process tool with the predefined template. (When the script is complete I have to end the current/last command manually).
As you can see, the extra characters do not appear on the first text elements. It also seems that the number of "words" in the junk text differs slightly between each text element.
Thanks. Nice to see that the problem could be reproduced.
Regards,Thomas HauglienSubsea CAD Engineerhttp://www.reinertsen.com/
Defect 110039 has be logged for this issue.
Answer Verified By: hauglien
thanks Jacquelyn Pettus
Please send code batch Process to email hoangvandoai@gmail.com
Thông tin liên hệ:Bất động sản Đại Lâm Mộc, thôn 3 Hoàng Tân Quảng Yên Quảng Ninh.Điện thoại: 0347668899Email: hoangvandoai@gmail.comWebsite: https://phuchophalongxanh.com/
