I just started using Power InRoads and I notice the InRoads Menu doesn't have "Modeler" in the menu bar anymore, but is now in the Civil Tool Task bar. Is there a way to get it back into the menu bar?? -geewizz
What version are you running?
SS2 should have it, Ss3, is new technology - Open Roads and does not use the Roadway Designer any more. It does still use the template editor, but the modeler is all done in MicroStation.
If you would like to use the native Modeler commands, you will need to revert to an SS2 version of InRoads. The latest SS2 release is 08.11.07.615. Modeler commands have been replaced in SS3 with OpenRoads Technology. You may want to take a look at the wiki below:
communities.bentley.com/.../10534.where-are-the-cross-section-and-modeler-commands-in-ss3.aspx
I'm using version 08.11.09.674. So doesn't use the roadway designer file (.ird) or template file (.itl) files anymore?
The ITL is still used in SS3. The IRD is not used anymore, however, existing IRD files can be imported: communities.bentley.com/.../12623.import-ird-into-openroads.aspx
Answer Verified By: geewizz
Great. Hmmm, can it export a design out to a .ird file. In the case, that if somebody else is using SS2 can use it.
