I have designed an alignment in Quick Alignment> vertical profile method.
Now I want to raise design string & ground line (exactly below center line) to 20m.
Means I want to give vertical offset to designed vertical profile & ground line.
Is there any method of vertical offsetting to design line & ground line so as to increase level by 20m for whole profile & ground line.
Thanks in advance
Please refer the below link for your reference.
communities.bentley.com/.../12712.how-to-copyoffset-survey-ground-model-with-the-distance-of-eg-2m-in-vertical-profile.aspx
Thanks Purva...
But there is no option like "MX> Modify > Copy > Scale and translate strings." in MXRoad SS3 and what about design line.
If I m giving a vertical offset to design line by using 120 option...it is not showing all IP raised by 20 m in Quick vertical alignment.
Thanks for your response.
The option is available in SS3 as well, please refer the attached snapshot below. You have to go through Modify > Copy > Scale and Translate strings.
Answer Verified By: onlinerahulsingh
It worked for ground model....
but what about design profile....how it would be raised by 20 m....how all the IP will be offset in one go???
Can you try to keep scale factors X=1, Y=1, Z=1 and then check it.
