I have designed an alignment in Quick Alignment> vertical profile method.
Now I want to raise design string & ground line (exactly below center line) to 20m.
Means I want to give vertical offset to designed vertical profile & ground line.
Is there any method of vertical offsetting to design line & ground line so as to increase level by 20m for whole profile & ground line.
Thanks in advance
When in Vertical Alignment Design if you select Edit Alignment there is an option to raise the Vertical Alignment as shown in the screen shot below.
Answer Verified By: onlinerahulsingh
Thanks Jason & Purva
Is it possible raising by quick alignment.
