Good morning,
The issue is taking a ditch a specific depth below existing ground line. What is the process to get a ditch a specific depth below existing ground line?
This is a little confusing to describe, so I recorded a video for you.
communities.bentley.com/.../16142.video-fixed-ditch-component.aspx
The final step in the process, which I did not demonstrate in the video, is to create a second priority test end condition that will solve if the existing ground is below the fixed ditch. I attached the template library to the wiki, and I completed this final step in that template.
Hope this helps!
Answer Verified By: Jacquelyn Pettus
Brilliant! Exactly what we needed, thank you Jacquelyn!
thanks this did it
thanks good tip, how does the benching work?
Check out this video on benching:
communities.bentley.com/.../9791.aspx
