I am running Inroads SS2 and trying to get my arms around template transitions. The problem is the edit transition dialog box only displays the backbone of the template. How do you control transitions outside the backbone? For example, how do you control the transition of an end condition going from a 1:1 catch slope to a 2:1?
Hi REJB,
If I understand your questions correctly you want to manually edit your end condition transitions. If so, this can be done with the End Condition Exceptions command and I have provided a link for you that demonstrates this process.
communities.bentley.com/.../13260.video-end-condition-exceptions-overrides.aspx.
Thanks!
Joe Lukovits
User Since TDP in the 80's,
Vax based Unix Workstations - Interpro32,
from the Intergraph Corp.
This is a typical entry for using parametric constraints. This is a transition by stations with slope changes from 1-2 slope to a 1-4 slope and back to 1-2. Remember that the default slope is 1-2 and will use 1-2 unless other wise noted. Parametric constraints can be used for Lane transitions as well.
