I am running Inroads SS2 and trying to get my arms around template transitions. The problem is the edit transition dialog box only displays the backbone of the template. How do you control transitions outside the backbone? For example, how do you control the transition of an end condition going from a 1:1 catch slope to a 2:1?
what you describe is what I want to do, but I do not see the end conditions in the Edit Transition dialog. I only see the backbone of the template. How do I view/edit the end conditions?
You access the end condition transitions through the End Condition Exceptions dialog. It gives you options for Overrides or Transitions. After you input the transition, either double-click it or click Edit at the bottom of the dialog box. It brings up an Edit Transition dialog, then an Edit Transition Midpoint dialog, just like the ones for the regular backbone transitions. I've attached a graphic...
Here's the screen graphic...
