Project settings at Startup Menu
Hey Guys,
I am setting up a MX user guide for my company, and i want to make it as easy as possible for people setting up MX for a new project and to create consistency.
I want to create a default project setting circled below in the attached image. However, when i paste the new file into the same location as AU_metric with a different name it does not appear in the drop down menu.
Any help would be greatly appreciated.
  • Can you attached the project setting file and I'll check it on my system.
  • I found out what was the problem when i was trying to paste the files into here.
    The file extension for my files was .+prm & .+gui. Not sure how the plus got added on, maybe when i copied from AU_metric. So when i removed the plus sign, it appeared in the drop down menu. Thanks for looking to help though.
  • However, i can see the file in the drop down menu, but when i start a new project and select it, MX freezes and eventually crashes.
    See attached in .txt format.
    * Version=08050000 	* Do not edit this line
    * PARAMETER FILE
    * THIS IS A DATA FILE WHICH HOLDS THE USER-CHANGEABLE SYSTEM DEFAULTS FOR
    * MOSS.
    * FILE FORMAT
    *           A) ANY DATA FOLLOWING AN ASTERISK '*' IS DESIGNATED A COMMENT
    *              AND IS IGNORED.
    *           B) EACH LINE OF DATA MUST BEGIN WITH A KEYWORD, WHICH MUST CONTAIN
    *              8 CHARACTERS AND BEGIN IN COLUMN 1.
    *           C) A KEYWORD MUST BE IMMEDIATELY FOLLOWED BY AN EQUALS SIGN '='.
    *              THERE MUST BE NO SPACES BETWEEN THE KEYWORD AND THE EQUALS SIGN.
    *           D) THE EQUALS SIGN MUST BE IMMEDIATELY FOLLOWED BY THE VALUE TO BE
    *              ASSIGNED TO THE SYSTEM PARAMETER. THERE MUST BE NO SPACES
    *              BETWEEN THE EQUALS SIGN AND THE VALUE. THE VALUE CAN BE REAL,
    *              INTEGER OR CHARACTER, BUT IT MUST BE OF THE SAME TYPE AS THE
    *              EXISTING PARAMETER.
    *           E) WHEN CHARACTER VALUES ARE USED THEY ARE ASSUMED TO BE 8
    *              CHARACTERS IN LENGTH. IF THE VALUE IS SHORTER THAN 8 CHARACTERS
    *              IT MUST BE PADDED OUT TO 8 CHARACTERS USING BLANKS.
    *           F) FOR TRANSLATION PURPOSES. INSERT A * IN COLUMN 9 FOR EVERY 5 OR
    *              SO LINES OF CONTINUOUS COMMENTS
    * PARAMETERS FOR METRIC/IMPERIAL CONVERSIONS
    * THESE PARAMETERS MUST PRECEDE ANY OTHER PARAMETERS WHICH ARE INPUT
    * IN METRIC OR IMPERIAL DISTANCES
    METR_IMP=1.0        * UNITS OF LINEAR MEASURE : 1.0=METRIC , 0.3048=IMPERIAL.
    MET2IMP2=1.0        * IMPERIAL/METRIC CONVERSION FACTOR(USED IN DRAW)
    *                       1.0 -METRIC
    *                       2.54-IMPERIAL
    *                       (CAN BE SET BY KODE18)
    * SYSTEM PARAMETERS
    LINEPAGE=-1        * NUMBER OF LINES PER PAGE.
    *                       MUST BE >  5
    *                       OR        -1  TO TURN PAGING OFF
    BANNEROP=0         * MOSS BANNER OUTPUT SWITCH
    *                      0 - NO BANNER OUTPUT
    *                      1 - BANNER OUTPUT (DEFAULT)
    LGSWITCH=1         * LOGGING FILE SWITCH
    *                      0 - NO LOG OF INPUT PRODUCED
    *                      1 - LOG OF INPUT PRODUCED ON MOSSV92INP.LOG
    LGIGSWCH=2         * LOGGING FILE SWITCH(IMOSS CURSOR HITS)
    *                      1 - LOG OF INPUT PRODUCED ON MOSSV92IGM.LOG
    *                      2 - LOG OF INPUT BUT NO ARCHIVE.
    TRIAPRNT=500       * MIN. NUMBER OF POINTS FOR TRIANGLE TRACE
    *                    MUST BE >1
    READINFO=30        * NUMBER OF TIMES README FILE MESSAGE IS INVOKED
    MODELIST=2         * MODEL LIST SORT ORDER
    *                      0 - AS STORED ON MODEL FILE
    *                      1 - ALPHABETICAL SORT
    *                      2 - DATE LAST USED IN REVERSE (DEFAULT)
    * UNIT PARAMETERS
    IN_ANGLE=0        * EXPECTED ANGULAR MEASURE INPUT UNITS.
    *                       THIS VALUE CAN BE MODIFIED DURING EXECUTION WITH 017
    *                       0 = DEG MIN SEC FOR MOST OPTIONS,DEG AND DEC FOR SOME
    *                       1 = DEGREES MINUTES AND SECONDS THROUGHOUT
    *                       2 = GRADS
    *                       3 = DEGREES AND DECIMAL DEGREES
    *                       4 = RADIANS
    *                       5 = QUADRANT BEARINGS
    OUT_ANGL=0        * EXPECTED ANGULAR MEASURE OUTPUT UNITS.
    *                           (IF QUAD_BER=1 THEN BEARINGS ARE OUTPUT IN
    *                                                        QUAD. BEARINGS)
    *                       2 = GRADS
    *                       4 = RADIANS
    QUAD_BER=0         * INDICATOR FOR QUADRANT BEARING ANGULAR MEASURE OUTPUT.
    *                       THIS VALUES CAN BE MODIFIED DURING EXECUTION WITH 017
    *                       0 = NO QUADRANT BEARINGS REQUIRED
    *                       1 = QUADRANT BERINGS REQUIRED
    *                           (IF THIS IS SET TO 1 THEN SET OUT_ANGL = 1)
    YXORD_IN=0        * INDICATOR FOR COORDINATE NOTATION FOR INPUT DATA.
    *                       0 = BRITISH,DANISH AND CZECH2 NOTATION
    *                       1 = USA,CZECH1,FAR EAST NOTATION
    YXORDOUT=0        * INDICATOR FOR COORDINATE NOTATION FOR OUTPUT DATA.
    *                       0 = BRITISH NOTATION  X/Y - EG. EASTING THEN NORTHING
    *                       1 = USA NOTATION      Y/X _ EG. NORTHING THEN EASTING
    *                       2 = DANISH NOTATION   Y/X _ EG. NORTHING THEN WESTING
    *                       3 = CZECH1 NOTATION   X/Y _ EG. SOUTHING THEN WESTING
    *                       4 = CZECH2 NOTATION   Y/X _ EG. WESTING THEN SOUTHING
    *                       5 = FAR EAST NOTATION X/Y _ EG. NORTHING THEN EASTING
    X_OSHIFT=0.0       * VALUE NEEDED TO BE ADDED TO NEGATIVE X COORDINATES
    *                    TO ENSURE ALL POSITIVE VALUES INTERNALLY
    *                    TYPICAL EXAMPLE 10000000.0
    Y_OSHIFT=0.0       * VALUE NEEDED TO BE ADDED TO NEGATIVE Y COORDINATES
    * ADDITIONAL OPTION 017 PARAMETERS
    CURVEFIT=1        * CURVE FITTING INDICATOR
    *                      0 - CURVE FITTING OFF
    *                      1 - CURVE FITTING ON (DEFAULT)
    TRIAECHO=0         * TRIANGLE ECHO ERROR
    *                      0 - NO ECHO (DEFAULT)
    *                      1 - NORMAL ECHO
    *                      2 - DOUBLE ECHO
    FLATTRIA=1        * ALLOW/BAN PRODUCTION OF FLAT TRIANGLES
    *                      O - DISALLOW FLAT TRIANGLES
    *                      1 - ALLOW FLAT TRIANGLES (DEFAULT)
    NVOFFSET=0         * SELECT NORMAL OR VERTICAL OFFSETS WITHIN
    *                    DESIGN OPTIONS THAT ALLOW NORMAL OFFSETS
    *                      0 - USE VERTICAL OFFSETS
    *                      1 - USE NORMAL OFFSETS
    SSTATLAB=PSSA      * SURVEY STATION STRING LABEL
    SINTTOLE=20.0      * SECONDARY INTERPOLATION TOLERANCE
    POINTTOL=0.01      * POINT SEARCH TOLERANCE
    SECTOFFL=-100.0        * LEFT SECTION OFFSET
    SECTOFFR=100        * RIGHT SECTION OFFSET
    BASEBEAR=0.0       * SECTION BASELINE BEARING
    *                    (SEE IN_ANGLE FOR UNITS = DECIMAL DEGREES)
    SINTOFFS=20.0        * SECONDARY INTERPOLATION OFFSET
    * DESIGN PARAMETERS
    AHDETOLR=0.100     * Default Chord-to-Arc tolerance
    *                    The chord-to-arc tolerance parameter only affects the
    *                     addition of points to the design / survey (202) ; it has NO
    *                    effect on the drawing.
    MRSWITCH=1         * RADIUS/M-VALUE SWITCH(USED IN VALGN)-FRENCH REQUIREMENT.
    *                      0 - M-VALUE USED WITHIN VALGN
    *                      1 - RADIUS USED WITHIN VALGN
    *                      2 - K-VALUE USED WITHIN VALGN
    RLADEFLT=0         * DEFAULT VALUE FOR TRANSITION USAGE (RL/A). USED IN
    *                    HALGN AND DRAW.
    *                      0 - RL
    *                      1 - A
    FDESWTCH=0         * FRENCH DESIGN 133 SWITCH - FRENCH REQUIREMENT.
    *                      0 - DESIGN 133 USES ENGLISH RULES
    *                      1 - DESIGN 133 USES FRENCH RULES
    CUBIFACT=0         * METHOD OF CUBIC TRANSITION CURVE CALCULATION
    *                      0 - WITHOUT FACTOR ADDED
    *                      1 - WITH FACTOR ADDED AND ENHANCED CURVE TO
    *                          CURVE CUBIC THEORY
    *                      3 - WITH NSW FACTOR ADDED
    *                      SEE USER MANUAL FOR DETAILS OF CUBIC FORMULA
    CUBILENG=0         * INPUT DEFINITION CUBIC TRANSITION LENGTH
    *                      0 - CURVE lENGTH
    *                      1 - TANGENT lENGTH
    *                          CUBIC TRANSITION LENGTH CALCULATION
    TRANLENG=0         * INPUT DEFINITION CURVE TO CURVE SAME HAND
    *                      TRANSITION LENGTH
    *                      0 - SPECIFIED LENGTH TO TRANSITION ORIGIN
    *                      1 - SPECIFIED LENGTH IS ACTUAL LENGTH
    * PLOTTER PARAMETERS.
    *PEN COLOURS REMOVED TO DRCOLOURS FILE
    INIMV_X1=0.0       * THESE THREE VALUES DETERMINE THE INITIAL PEN MOVE.
    INIMV_Y1=0.0       * THEY ARE USED THUS:    CALL PLOT(X1,Y1,3)
    INIMV_Y2=0.0       *                     +  CALL PLOT(X1,Y2,-3)
    *                    SET THE THREE VALUES TO 0.0 IF YOU DON'T WANT AN
    *                    INITIAL PEN MOVE
    *                    SET THE THREE VALUES AS FOLLOWS TO MOVE THE PEN
    *                    TO RIGHT HAND SIDE FOR A DRUM PLOTTER
    *                       INIMV_X1=10.0
    *                       INIMV_Y1=-75.0
    *                       INIMV_Y2=-70.0
    ARSWITCH=0         * EXTENDED .PIC FILE FUNCTIONALLITY.
    *                      0 - NOT EXTENDED
    *                      1 - EXTENDED
    PICOORDS=1.0       * UNITS IN WHICH COORDINATES ARE HELD ON THE PICTURE FILE.
    *                      1.0       - CENTIMETRES.
    *                      0.3937009 - INCHES.
    CHARATIO=100       * CHARACTER WIDTH/HEIGHT RATIO*100. IF YOUR INSTALLATION'S
    *                      SUBROUTINE SYMBOL ALLOWS TEXT TO BE CONTINUED WITH
    *                      THE X=999.0,Y=999.0 FACILITY, USE VALUE -1.
    * DRAW PARAMETERS.
    DPAPORIN=1         *  SHEET ORIENTATION          : 1 = LANDSCAPE
    *                                                : 2 = PORTRAIT
    DPAPTYPE=0         *  PAPER TYPE (800)           : 0 = INTERACTIVE
    *                                                : 1 = PLOTTER
    DEFPAGLN=84.1      *  DEFAULT PAGE LENGTH (800)  : +VE REAL NO.
    *                                                : (EG. 'A1' LENGTH = 84.1)
    DEFPAGWD=59.4      *  DEFAULT PAGE WIDTH (800)   : +VE REAL NO.
    *                                                : (EG. 'A1' WIDTH = 59.4)
    DPAGMAXL=400.0     *  MAXIMUM ALLOWABLE PAGE     : +VE REAL NO. (INSTALLATION
    *                      LENGTH (800)              : DEPENDENT)
    DPAGMAXW=400.0     *  MAXIMUM ALLOWABLE PAGE     : +VE REAL NO. (INSTALLATION
    *                      WIDTH (800)               : DEPENDENT)
    DFACPLOX=1.0       *  X PLOT FACTOR (800)        : +VE REAL NO.
    DFACPLOY=1.0       *  Y PLOT FACTOR (800)        : +VE REAL NO.
    DMARSIZE=2.0       *  MARGIN SIZE (802)          : +VE REAL NO.
    DPAGEING=0         * P AGEING (803)              : 0 = NO PAGEING
    *                                                : 1 = PAGEING
    DATRUNCN=1         *  TRUNCATION (803)           : 0 = NO TRUNCATION
    *                                                : 1 = TRUNCATION
    DPENCOLR=1         *  PEN COLOUR (805 AND 806)   : 1 = BLACK
    *                                                : 2 = RED
    *                                                : 3 = GREEN
    *                                                : 4 = BLUE
    *                                                : 5 = CYAN
    *                                                : 6 = YELLOW
    *                                                : 7 = ORANGE
    *                                                : 8 = PINK
    *                                                : 9 = GREY
    *                                                : 10= PALEBLUE
    *                                                : (INSTALLATION DEPENDENT,
    *                                                :  IN DRCOLOURS.DAT)
    DCHRTYPE=N         *  CHARACTER TYPE (808)       : N = NO CONVERSION
    *                                                : L = ALL CHARACTERS LOWERCASE
    *                                                :      (MACHINE DEPENDENT)
    *                                                : U = ALL CHARACTERS UPPERCASE
    DCHARHYT=0.25      *  CHARACTER HEIGHT (808)     : +VE REAL NO.
    DNUMDECP=3         *  NO. OF DECIMAL PLACES (808): +VE INTEGER NO.
    DCHRATIO=1.0       *  CHARACTER ASPECT RATIO     : +VE REAL NO. (GKS MACHINE
    *                      (WIDTH/HEIGHT) (808)      : DEPENDENT)
    DCHARSPC=0.0       *  CHARACTER SPACING (808)    : +VE REAL NO. (GKS MACHINE
    *                                                : DEPENDENT)
    DLINSPAC=0.5       *  LINE SPACING INTERVAL      : +VE REAL NO. RELATED TO
    *                      FOR TEXT (808)            : CHARACTER HEIGHT
    *                      RATIO OF CH. HT.
    DFONTYPE=          *  DEFAULT FONT NAME (808)    :      = USE H/W FONT
    *                                                : SOF1 = DEFAULT S/W FONT1.MFF
    *                                                : SOFn = USER S/W FONT n
    *                                                         FONT2.MFF to
    *                                                         FONT9.MFF
    DFRAMTYP=0         *  FRAME TYPE (821)           : 0 = NO FRAME
    *                                                : 1 = FRAME
    *                                                : 2 = WINDOW
    *                                                : 3 = REGISTRATION MARKS
    DGRDTIKX=1.0       *  GRID X TICK SIZE (822)     : +VE REAL NO.
    DGRDTIKY=1.0       *  GRID Y TICK SIZE (822)     : +VE REAL NO.
    DINTSEQP=1         *  POINT SEQUENCE NUMBER      : +VE INTEGER NO.
    *                      INTERVAL (825)            :
    DLABTYPE=0         *  LABELS (825 AND 826)       : 0 = NO LABEL
    *                                                : 1 = LABEL
    DPIPLENG=0.1       *  PIP LENGTH (825 AND 860)   : +VE REAL NO.
    DSYMLENG=1.0       *  STANDARD SYMBOL LENGTH AS  : +VE REAL NO.
    *                      A PROPORTION OF CURRENT   :
    *                      CHARACTER SIZE (825(DETA)):
    DCHMAINT=50.0     *  CHAINAGE MARKING INTERVAL  : +VE REAL NO.
    *                      (826,866,867)             :
    DOFFSEQP=0.5       *  TEXT OFFSET OF POINT       : REAL NO.
    *                      SEQUENCE NUMBER (PSN)(865):
    DPSNMINT=1         *  PSN MARKING INTERVAL (865) : +VE INTEGER NO.
    DCHAMPIP=0.1       *  CHAINAGE MARKING PIP       : +VE REAL NO.
    *                      SIZE (866)                :
    DCHAMOFF=0.5       *  CHAINAGE MARKING TEXT      : REAL NO.
    *                      OFFSET (866)              :
    DCHAMAPI=0.1       *  CHAINAGE-BOTH-SIDE-MARKING : +VE REAL NO.
    *                      PIP SIZE (867)            :
    DCHAMAOF=-0.5      *  CHAINAGE-BOTH-SIDE-MARKING : REAL NO.
    *                      TEXT OFFSET (867)         :
    DSPOTLEV=0.5       *  SPOT LEVEL TEXT            : REAL NO.
    *                      OFFSET (868)              :
    DSTRAOFF=0.5       *  STRING DIMENSION ANNOTATION: REAL NO.
    *                      TEXT OFFSET (869)         :
    DHATANGL=0.0       *  HATCHING ANGLE (DEGREES)   : REAL NO.
    *                      (875,877,879,891,892,893) :
    DHATSPAC=0.25      *  HATCH SPACING (CMS)        : REAL NO.
    DGRADTYP=0         *  GRADIENT IN PERCENT  = 0   : INTEGER NO.
    *                                 PERMILLE = 1   :
    *                      (864,7=-23)
    *                      THIS SWITCH WILL ONLY OPERATE IF PERCENT HAS
    *                      BEEN REQUESTED ON OPTION 809 OR SET BY
    *                      THE KEYWORD XFCANDEF (BELOW)
    DCLOTHTY=0         *  CLOTHOID ANNOTATION        : INTEGER NO.
    *                       CL = 0
    *                       RP = 1
    *                      (869,4=-25)
    DRDSCALE=500        *  DEFAULT DRAWING SCALE      : REAL NO.
    *                      (803)
    DINFISYM=1         *  MACRO SYMBOL SWITCH FOR INFINITY RADII
    *                        0 - PRINT OUT "INFINITY"
    *                        1 - USE MACRO SYMBOL
    DREALINT=0         *  SWITCH TO DETERMINE WHETHER PARTIAL DISTANCES
    *                     ARE CALCULATED USING REAL OR INTERPOLATED POINTS
    *                     ON A PAGED DRAWING
    *                        0 - USE REAL POINTS
    *                        1 - USE INTERPOLATED POINTS
    DGSTGCOD=1         *  GEOMETRY STRING CODES       :INTEGER NO.
    *                         VALID CODES:
    *                       1. HTPS - HORIZONTAL TANGENT POINTS
    *                       2. HIPS - HORIZONTAL INTERSECTION POINTS
    *                       3. HCEN - HORIZONTAL ARC CENTRES
    *                       4. VTPS - VERTICAL TANGENT POINTS
    *                       5. VIPS - VERTICAL INTERSECTION POINTS
    *                       6. VFPS - VERTICAL FLAT POINTS
    *                       7. VMOS - VERTICAL MID-ORDINATE POINTS
    *                       8. SUPE - SUPERELEVATION ANNOTATION
    XFCANDEF=11        *  SUPERELEVATION UNITS
    *                     (809,field 4)
    *                     This value is interpreted as two columns.
    *                     10's column :
    *                     CROSSFALL UNITS          1* = PERCENT
    *                                              2* = DECIMAL PERCENT
    *                                              3* = 1:N
    *                     units value if metric :
    *                     CANT UNITS (METRIC)      *1 = METRES
    *                                              *2 = CENTIMETRES
    *                                              *3 = MILLIMETRES
    *                     units value if imperial :
    *                     CANT UNITS (IMPERIAL)    *1 = DECIMAL FEET
    *                                              *2 = DECIMAL INCHES
    CLUTTEXT=1         *  CLUTTERED TEXT SWITCH
    *                        0 - DO NOT REMOVE CLUTTERED TEXT
    *                        1 - REMOVE CLUTTERED TEXT
    * GEOMETRY STRING ANNOTATION
    * Draw minor option 869 allows you to output Horizontal and Vertical
    * Tangent point data start/end labels
    * The default start/end labels are shown for Horizontal and Vertical
    * between - and =, the definition of the label is shown after the *.
    * To change the label appended to the drawing using DRAW minor option
    * 869 field 4=-46;
    * Enter after the = strt and end labels
    * Examples
    *       ABCD/ABCD gives start label ABCD and end label ABCD
    *       ABCD/EFGH gives start label ABCD and end label EFGH
    *       /EFGH gives end label EFGH only
    *       ABCD/ gives start label ABCD only
    * Notes
    * If between = and * is blank, the code between - and = is used.
    * A maximum of 4 characters are permitted either side of the /.
    * THE CODES ARE UNNECESSARY FOR BRITISH ANNOTATION AND HAVE
    * THEREFORE BEEN COMMENTED OUT IN THE FOLLOWING LINES
    * IF THE SPECIAL ANNOTATION IS REQUIRED - REMOVE THE
    * ASTERISK AND SPACE IN FRONT OF EACH LINE COMMENCING
    * WITH GEH OR GEV BELOW.
    * HORIZONTAL             ELEMENT BEFORE        CODE    ELEMENT AFTER
    * GEH-PBT =/GA       *         NONE              PBT      STRAIGHT
    * GEH-PBC =/BA       *         NONE              PBC      ARC
    * GEH-PAT =GE/       *         STRAIGHT          PAT      NONE
    * GEH-PAC =BE/       *         ARC               PAC      NONE
    * GEH-TS  =GE/UA     *         STRAIGHT          TS       SPIRAL
    * GEH-ST  =UE/GA     *         SPIRAL            ST       STRAIGHT
    * GEH-CS  =BE/UA     *         ARC               CS       SPIRAL
    * GEH-SC  =UE/BA     *         SPIRAL            SC       ARC
    * GEH-SS  =UE/UA     *         SPIRAL            SS       SPIRAL
    * GEH-PC  =GE/BA     *         STRAIGHT          PC       ARC
    * GEH-PT  =BE/GA     *         ARC               PT       STRAIGHT
    * GEH-PRC =BE/BA     *         ARC               PRC      ARC
    * GEH-PCC =BE/BA     *         ARC               PCC      ARC
    * VERTICAL               ELEMENT BEFORE        CODE    ELEMENT AFTER
    * GEV-PBT =/GA       *         NONE              PBT      GRADE
    * GEV-PBC =/BA       *         NONE              PBC      CURVE
    * GEV-PAT =GE/       *         GRADE             PAT      NONE
    * GEV-PAC =GA/       *         CURVE             PAC      NONE
    * GEV-PT  =BE/GA     *         CURVE             PT       GRADE
    * GEV-PC  =GE/BA     *         GRADE             PC       CURVE
    * GEV-TT  =GE/GA     *         GRADE             TT       GRADE
    * GEV-VX  =BE/BA     *         CURVE             VX       CURVE
    *       *            *             Curve high or low point
    * GEV-VM  =BE/BA     *         CURVE             VM       CURVE
    *                    *             Curve middle ordinate point
    * GEV-PCC =BE/BA     *         CURVE             PCC      CURVE
    *                    *             Curve same sense
    * GEV-PRC =BE/BA     *         CURVE             PRC      CURVE
    *                    *             Curve opposite sense
    * GEV-VMX =BE/BA     *         CURVE             VMX      CURVE
    *       *            *             Curve coincident high or low
    *                    *             and middle ordinate point
    * STANDARD/CURVED INTERFACE PARAMETERS
    GRADINTR=0.667     * DEFAULT GRADIENT FOR STANDARD/CURVED INTERFACE
    TANGINTR=3.0       * DEFAULT TANGENT LENGTH FOR STANDARD/CURVED INTERFACE
    WDTHINTR=2.0       * DEFAULT DITCH WIDTH FOR STANDARD/CURVED INTERFACE
    DPTHINTR=0.3       * DEFAULT DITCH DEPTH FOR STANDARD/CURVED INTERFACE
    * ALIGNMENT PARAMETERS
    * HORIZONTAL DISPLAY
    *   Available colours                   Available line styles
    *     1 --- Black                           1 --- Solid
    *     2 --- Red                             2 --- Dashed
    *     3 --- Green                           3 -- Dotted
    *     4 --- Blue                            4 -- Dot/dash
    *     5 --- Cyan
    *     6 --- Yellow
    *     7 --- Orange
    *     8 --- Pink
    *     9 --- Grey
    *     10--- Paleblue
    AHDIBGDC=5         * Background colour
    AHDIBGDS=1         * Background style
    AHDISGDC=5         * Spline Background colour
    AHDISGDS=1         * Spline Background style
    AHDIELEC=6         * Element colour/working colour
    AHDIELES=1         * Element style/working style
    AHDISLEC=6         * Spline element colour/working colour (splines)
    AHDISLES=1         * Spline element style/working style (splines)
    AHDISTRC=5         * Straights colour
    AHDISTRS=1         * Straights style
    AHDIARCC=3         * Arcs colour
    AHDIARCS=1         * Arcs style
    AHDITRNC=6         * Trans colour
    AHDITRNS=1         * Trans style
    AHDIDIRA=1         * Direction arrows        1 --- Drawn
    *                                            2 --- Not drawn
    AHDITPTM=1         * Tangent point markers   1 --- Drawn
    *                                            2 --- Not drawn
    AHDITXAN=1         * Auto annotation switch  1 --- Yes
    *                                            2 --- No
    * HORIZONTAL DESIGN
    * The chord-to-arc tolerance is held in AHDETOLR under the DESIGN
    * parameters.
    AHDEDESP=120.000   * Design speed
    AHDEMINR=250.000   * Minimum radius for spline alignments
    AHDERCLA=0.300     * Maximum RCLA
    AHDEDESM=1         * Design methods       1 --- Element
    *                                         2 --- I.P.
    *                                         3 --- Spline
    AHDERADU=1         *                      1 --- Radius
    *                                         2 --- DOC (A)
    *                                         3 --- DOC (C)
    AHDECRVI=1         * Curve intersection methods (I.P. only )
    *                                         1 --- 3IPS
    *                                         2 --- ALL IPS
    AHDETRNR=1         * Transition rules     1 --- None
    *                                         2 --- French roads
    *                                         3 --- Dutch rail
    *                                         4 --- German rail
    AHDETRNF=1         * Transition formulae  1 --- Clothoid
    *                                         2 --- Bloss
    *                                         3 --- Cubic
    *                                         4 --- Bi-quadratic
    *                                         5 --- Sine
    *                                         6 --- Notrans
    AHDECDBY=6         * Clothoid defined by
    *                                         1 --- Rules
    *                                         2 --- N/A
    *                                         3 --- A value
    *                                         4 --- RL value
    *                                         5 --- Speed
    *                                         6 --- Length
    AHDECOBY=2         * Clothoid overriden by
    *                                         1 --- N/A
    *                                         2 --- Length
    *                                         3 --- RL value
    *                                         4 --- A value
    *                                         5 --- Speed
    AHDEC__A=400.000   * Clothoid defined by A value
    AHDEC_RL=114590.0  * Clothoid defined by RL value
    AHDEC_SP=100.000   * Clothoid defined by SPEED
    * DUTCH TRANSITION
    AHDTDESS=0.000     * Design speed
    AHDTDEFF=0         * Default deficiency factor
    AHDTGRDT=1         * Default gradient type
    *                                          1 --- 1:10V
    *                                          2 --- 1:8V
    AHDTMITC=20.000    * Minimum theoretical crossfall
    AHDTMATC=270.000   * Maximum theoretical crossfall
    AHDTMAAC=150.000   * Maximum allowable crossfall
    * FRENCH TRANSITION
    AHFTDESS=1         * Design speed         1 --- 40
    *                                         2 --- 60
    *                                         3 --- 80
    *                                         4 --- 100
    *                                         5 --- 120
    AHFTNOLA=1         * Number of lanes      1 --- 2
    *                                         2 --- 3
    *                                         3 --- 4
    AHFTRDCL=1         * Road classification  1 --- AR
    *                                         2 --- RP
    *                                         3 --- UR
    * VERTICAL DISPLAY
    *     3 --- Green                           3 --- Dotted
    *     4 --- Blue                            4 --- Dot/dash
    *     5 --- Cyan
    *     6 --- Yellow
    *     7 --- Orange
    *     8 --- Pink
    *     9 --- Grey
    *     10--- Paleblue
    AVDIBGDC=5         * Background colour
    AVDIBGDS=1         * Background style
    AVDISGDC=5         * Spline Background colour
    AVDISGDS=1         * Spline Background style
    AVDIELEC=6         * Element colour/working colour
    AVDIELES=1         * Element style/working style
    AVDISLEC=6         * Spline element colour/working colour
    AVDISLES=1         * Spline element style/working style
    AVDIGRDC=5         * Grades colour
    AVDIGRDS=1         * Grades style
    AVDIHOGC=2         * Hog curves colour
    AVDIHOGS=1         * Hog curves style
    AVDISAGC=3         * Sag curve colour
    AVDISAGS=1         * Sag curve style
    AVDIVTPS=1         * Vertical T.P's
    AVDIDIRM=1         * Direction markers    1 --- Drawn
    *                                         2 --- Not drawn
    AVDIHTPS=1         * Horizontal T.P's     1 --- Drawn
    *                                         2 --- Not drawn
    AVDIVERM=1         * Vertex markers       1 --- Drawn
    *                                         2 --- Not drawn
    AVDITXAN=1         * Auto annotation switch  1 --- Yes
    *                                            2 --- No
    * VERTICAL DESIGN
    AVDEDESM=4         * Design method        4 --- Element
    *                                         5 --- IP
    *                                         6 --- Spline
    AVDECURP=2         * Curve parameter      1 --- M-value
    *                                         2 --- Radius
    *                                         3 --- K-value
    AVDECUIM=1         * Curve intersection method (I.P. only)
    *                                         1 --- 3-IPS
    *                                         2 --- ALL IPS
    AVDEEMHG=0.000     * Extreme M value, hog
    AVDEEMSG=0.000     * Extreme M value, sag
    AVDEERHG=0.000     * Extreme radius, hog
    AVDEERSG=0.000     * Extreme radius, sag
    AVDEEKHG=0.000     * Extreme K value, hog
    AVDEEKSG=0.000     * Extreme K value, sag
    AVDEMAGD=0.000     * Maximum gradient
    AVDEMIGD=0.000     * Minimum gradient
    AVDEDMHG=10.000    * Default M value, hog
    AVDEDMSG=10.000    * Default M value, sag
    AVDEDRHG=1000.0    * Default radius, hog
    AVDEDRSG=1000.0    * Default radius, sag
    AVDEDKHG=10.000    * Default K value, hog
    AVDEDKSG=10.000    * Default K value, sag
    AVDEMICL=0.000     * Minimum curve length
    AVDEDLHG=100.000   * Default length, hog
    AVDEDLSG=100.000   * Default length, sag
    AVDEKVAL=1         * K value              1 --- UK
    *                                         2 --- AASHTO
    AVDEDESS=120       * Design speed
    AVDECREC=2         * Crest criterion
    *                                         1 --- Overtake
    *                                         2 --- Desmin
    *                                         3 --- Absmin
    * SUPERELEVATION PARAMETERS
    * SUPERELEVATION DISPLAY
    SUPCOLOR=2         * Superelevation applied colour
    *                    See HORIZONTAL DISPLAY for available
    *                    colours
    * SUPERELEVATION DESIGN
    SUPAPPLI=1         * Application              0 --- None
    *                                             1 --- Crossfall
    *                                             2 --- Cant
    * CROSSFALL PARAMETERS
    CROSUNIT=2         * Crossfall units          1 --- Percent
    *                                             2 --- Decimal
    *                                                   percent
    *                                             3 --- 1 : N
    CROSTHEO=0         * Theoretical Crossfall    0 --- Not applied
    *                                             1 --- Applied
    CROSFACT=2.828     *Theoretical Crossfall factor
    CROSROUN=1         * Rounding for crossfall   1 --- Nearest
    *                                             2 --- Up
    *                                             3 --- Down
    CROSTLPC=0.5       * Round up, down or to the nearest
    *                    (percent)
    CROSTLDC=0.005     * Round up, down or to the nearest
    *                    (decimal percent)
    CROSTL1N=20.0      * Round up, down or to the nearest (1:N)
    CROSMNPC=3.0       * Minimum crossfall (percent)
    CROSMNDC=0.030     * Minimum crossfall (decimal percent)
    CROSMN1N=33.0      * Minimum crossfall (1:N)
    CROSMXPC=7.0       * Maximum crossfall (percent)
    CROSMXDC=0.07      * Maximum crossfall (decimal percent)
    CROSMX1N=15.0      * Maximum crossfall (1:N)
    CROSINPC=2.5       * Inflection crossfall (percent)
    CROSINDC=0.025     * Inflection crossfall (decimal percent)
    CROSIN1N=40.0      * Inflection crossfall (1:N)
    * CANT PARAMETERS
    CANTUNMT=1         * Cant units (metric)   1 --- mms
    *                                          2 --- cms
    *                                          3 --- metres
    CANTUNIM=1         * Cant units (Imperial) 1 --- inches
    *                                          2 --- feet
    CANTTHEO=0         * Theoretical Cant      0 --- Not applied
    *                                          1 --- Applied
    CANTFACT=0.085     * Theoretical Cant factor
    CANTROUN=1         * Rounding for cant     1 --- Nearest
    *                                          2 --- Up
    *                                          3 --- Down
    CANTTLMM=5.0       * Round up, down or to the nearest (mm)
    CANTTLCM=0.5       * Round up, down or to the nearest (cm)
    CANTTLMT=0.05      * Round up, down or to the nearest (metre)
    CANTTLIN=0.5       * Round up, down or to the nearest (inch)
    CANTTLFT=0.042     * Round up, down or to the nearest (foot)
    CANTMNMM=0.0       * Minimum cant (mm)
    CANTMNCM=0.0       * Minimum cant (cm)
    CANTMNMT=0.0       * Minimum cant (metre)
    CANTMNIN=0.0       * Minimum cant (inch)
    CANTMNFT=0.0       * Minimum cant (foot)
    CANTMXMM=150.0     * Maximum cant (mm)
    CANTMXCM=15.0      * Maximum cant (cm)
    CANTMXMT=0.15      * Maximum cant (metre)
    CANTMXIN=6.0       * Maximum cant (inch)
    CANTMXFT=0.5       * Maximum cant (foot)
    CANTINMM=0.0       * Inflection cant (mm)
    CANTINCM=0.0       * Inflection cant (cm)
    CANTINMT=0.0       * Inflection cant (metre)
    CANTININ=0.0       * Inflection cant (inch)
    CANTINFT=0.0       * Inflection cant (foot)
    * END OF SUPERELEVATION PARAMETERS
    * CREATE M-STRING PARAMETERS
    CRMCHINT=5.0      * Chainage interval
    CRMDRAWM=1         * Draw master string 1 = Yes
    *                                       0 = No
    * END OF CREATE M-STRING PARAMETERS
    * Railway params:
    TOGLCON1=1         * component library
    *                  * 1=Type 1
    *                  * 2=Type 2
    RAILGAUG=1435.0    * STANDARD RAIL GAUGE PARAMETER (millimeters)
    * PARAMETERS FOR 3 CENTRE CURVES
    TCCANG01=15.75     * SUBTENDED ANGLE OF ARC 1.
    TCCANG03=20.25     * SUBTENDED ANGLE OF ARC 3.
    TCCRAT01=2.0       * RATIO OF RADIUS OF ARC 1 TO RADIUS OF ARC 2
    TCCRAT03=3.0       * RATIO OF RADIUS OF ARC 3 TO RADIUS OF ARC 2
    * PARAMETERS FOR ITALIAN 3 CENTRE CURVES
    TCCANC  =0.6       * MAX LATERAL ACCELERATION
    TCCANCD =0.6       * MAX LATERAL ACCELERATION (FREIGHT COMPONENT)
    TCCC    =0.15      * RATE OF CHANGE OF LATERAL ACCELERATION
    TCCI01  =0.2       * CANT GRADIENT (V>75)
    TCCI02  =0.15      * CANT GRADIENT (75<V<=100)
    TCCI03  =0.1       * CANT GRADIENT (100<V<=125)
    TCCI04  =0.1       * CANT GRADIENT (125<V<=160)
    TCCVELO =155.0     * ITALIAN DESIGN SPEED
    * DRAINAGE PARAMETERS
    DRAIPROG=4         * Default program  1 --- Wallrus
    *                                     2 --- MicroRAT
    *                                     3 --- MicroDrainage Windes Version 5
    *                                     4 --- MicroDrainage Windes Version 6/7
    DRAIMEAS=2         * Default measurement method 1 --- edge to edge
    *                                               2 --- centre to centre
    DRAIRETP=1         * Global variable 1 - Return period (years-max=99)
    DRAILOCA=1         * Global variable 2 - Location (1=Eng&Wales)
    DRAIM560=15        * Global variable 5 - M5-60 (mm)
    DRAIRATI=0.5       * Global variable 6 - Ratio
    DRAIMXRF=20        * Global variable 8 - Maximum rainfall (mm)
    DRAIGTOE=5         * Global variable 13- Global time of entry (mins)
    PROXCHCK=1         * Manhole and branch proximity check with carriageway
    *                    1 = on
    *                    2 = off
    PIPEDIST=1.0       * Minimum distance for pipe proximity check
    PIPESIZE=0.15      * Nominal pipe size for pipe proximity check (diameter m)
    MANHDIST=0.5       * Minimum distance for manhole proximity check
    DEFMASK1=C         * Default mask 1 to be included in mask for proximity check
    DEFMASK2=C         * Default mask 2 to be included in mask for proximity check
    DEFMASK3=C         * Default mask 3 to be included in mask for proximity check
    DEFMASK4=C         * Default mask 4 to be included in mask for proximity check
    *                    The above masks can only be 4 characters long and must be
    *                    the first 4 characters after the = sign
    LNGTCHCK=1         * Drainage length checking as manholes are linked
    *                    1 = on
    *                    2 = off
    LNGTDIST=100.0     * Maximum distance for drainage pipe length checking
    * IGMACRO COLOURS
    *   Available colours
    *     1 --- Black
    *     2 --- Red
    *     3 --- Green
    *     4 --- Blue
    *     5 --- Cyan
    *     6 --- Yellow
    *     7 --- Orange
    *     8 --- Pink
    *     9 --- Grey
    *     10--- Paleblue
    MACMESH1=5         * Mesh 1 colour
    MACMESH2=4         * Mesh 2 colour
    MACORIGN=2         * Origin colour
    MACPDPER=3         * Pen Down permiable line colour
    MACPDIMP=6         * Pen Down impermiable line colour
    MACPUIMP=1         * Pen up impermiable line colour
    * COMPRESS FLAG
    COMPRESS=1         * During COMPRESS create archive file as
    *                    0 = Temporary file
    *                    1 = Permanent file
    SKEWSECT=0         * set skew section flag
    KINKBLOC=0         * set kink block flag
    *Survey Parameters
    CURVCORR=1                 *  Curvature correction                 : 0 = Curvature correction  OFF
    *                           (Survey minor option 200 field 8)      : 1 = Curvature correction  ON
    *Working v Final Drawing Parameter
    MXAPPDRG=0                 *  0 = Use working drawings
    *                             1 = Use final drawings
    *SWITCH TO DETERMINE WHETHER TO INTERPOLATE OR PUT A DISCONTINUITY WHERE NO INTERFACE IS FOUND
    INTERDIS=0                 *  0 - IF THERE IS NO INTERFACE FOUND
    *                                 AT A SECTION THEN INTERPOLATE BETWEEN THE SECTIONS
    *                             1 - IF THERE IS NO INTERFACE FOUND
    *                                 PUT A DISCNTINUITY BETWEEN THE SECTIONS
    STRINGNC=1                 *  0 - String Naming Convention will not be enabled
    *                                  when a new project is created
    *                             1 - String Naming Convention will be enabled
    FINI
    the parts edited are and what changed to from the default:
    • BANNEROP=0
    • DCHARHYT=0.25
    • DCHMAINT=50.0
    • DRDSCALE=500
    • AHDETRNF=1
    • AHDECDBY=6
    • AHDECOBY=2
    • AVDECURP=2
    • CROSMNPC=3.0
    • CROSMNDC=0.030
    • CROSMN1N=33.0
    • CRMCHINT=5.0
  • The file you attached seems to have gaps or spaces added which are causing a problem, it's very important to carefully edit the parameter file to make sure no gaps or spaces are added.
    It is recommended to use the Parameter File editor when changing the file as opposed to a text editor. this can be found on the MX Properteis tool panel (Programs>Bentley>MX v8i>MX Options)
    Can you check that the attached parameter file works for you. It has been set up with your values and checked with the Parameter File editor for errors.
    3036.Op_metric.prm
  • Thanks Jason worked a treat. Is there anyway you can load the recover wizard from the parameters file?
    Dave
