Hello
I have a question , Is there is a tool in Inroads SS2 similar to plan view labeling which is in GEOPAK so I can do labels similar to the attached picture.Mahmoud
Yes, try the command Drafting > Place Plan Note.
Answer Verified By: Chris Key
Thank you
I have another question in GEOPAK we used to label the Curves as in the attached picture "Radius , Length and Delta" , Is this possible in Inroads.?
Yes, the command Geometry>View Geometry>Curve Set Annotation will do this.
I already tried to use Annotate Graphics that gave me results similar to what I was able to get using GEOPAK but without getting the data inside the circle and without the arrow.
Unfortunately, we do not have a command that can place the circle and arrow around the curve data.
