I am encountering an error message "Cannot open source file" whenever I try to analyze or design a network in GEOPAK drainage. I reconstructed a totally blank project with only a small area, a node, an outfall, and the connecting pipe to ensure it was not something corrupt in the file. I have closed and reopened the program several times. I have cleared all the resource files from my temp folder and the GEOPAK 8.11.9 per other forum suggestions from years ago. I have tried moving the .gdf file to several places that I was positive had no read/write protections. I have checked my user preferences COGO preferences to ensure they are mapped to the correct place, and still... no luck. Any advice would be much appreciated. Thanks!
I am using PowerMicrostation V8i (SELECT 4 series)
Melody Wright said:I am using PowerMicrostation V8i (SELECT 4 series)
It looks like you're using GEOPAK as well?
Melody Wright said:per other forum suggestions from years ago
Presumably the GEOPAK Forum? That's probably a better place to post your question. We don't know anything about .gdf files here.
.gdf
