I'm changing the Linear stroking value of the 3D line of a geometrical object by selecting the object and changing this manually using the Properties window.
I'd like to create a Feature Definition so that the 3D line created will default to have the stroking values I will preset but I can't find the setting to add or change this.
Or is this even possible?
Hi Chris,
It's not possible for now, but you can add theis enhancement idea in the Idea portal,
There is already a similar request
https://bentleyopencivil.ideas.aha.io/ideas/BCI-I-522
Vincent RAULT [Bentley]
Thanks. I put my comment on the request on the Idea portal to push for the enhancement.
