After i select location from GeoLocat and click on the ESRI Layer button the ESRI Basemap window opens and i get the following error message in the Map List box: Could not connect to service, check URL
This is an extremely fundamental service for Siteops. Anyone have any clues on how to fix this?
Same here - does anyone else have the same issue/ has had any luck getting this fixed? Thanks!
Am I still having the same issue. Has anyone solved this?
