Hi Everyone,I'm having problems with getting the detailed reinforcement drawings for the already designed structural elements (beams, columns and footings). I already tried the "framing dxf" and the "col_foot dxf" commands on RAM Manager but the output is not concise. Is there a way to get the reinforcement drawings for all the designed elements ? I would really appreciate the help.
The dxf export options from Manager (or Ram Frame for braced frame elevations) are the only drawings directly created by the program. For some, like concrete beams, there are options whether to generate a schedule or drawings for each beam line.
The other thing you can do is export the full 3D model with reinforcing to ISM and pull that model into a concrete detailing package like ProStructures.
