Hi
Can I be able to use metric formula ( 0.613 Kz Kzt Kd V² ) if I will use the "calculate as per asce" button in wind load definition?
I notice that I can change the units of the dimension of the building but the formula remains the same.
Thanks.
Dave: Although the inputs can be specified in Metric units however the program internally converts these to English units and uses the equations corresponding to English formula. After the calculations are done, the pressure vs height data is reported back in Metric units.
Answer Verified By: Dave Jason Narca
