Recently I've updated from STAAD.Pro SS 5 to SS 6. Unfortunately, a few things changed negatively and I'm wondering if I can change them back:
1. Axial force diagram has switched colours (red/blue) from before ... so now a tension member is showing blue instead of red as before. This is confusing. I know I can manually change back the colours as before, but is there a way to change the defaults so they view as I'd like them to from the start?
2. I used to be able to hover my cursor over a node and a pop up would appear showing displacement and force results for the current load case. Now, hovering the mouse just shows the node number. Any way to get that functionality back? This was a handy feature!
Neil
Answer Verified By: Corneil Byl
