Hi anyone please post me the code for extracting nodal displacement from staad
Mallesh
You can use the following code to extract the node displacement value --
Dim Node As LongDim Lcase As LongDim Disp(0 To 5) As Double
Node = <specify the node number>
Lcase = <specify the load case number>
objOpenSTAAD.Output.GetNodeDisplacements Node, Lcase, Disp
You can create a For loop to print the Disp array.
Thanks Suro, i could able to do it
