I'm having trouble understanding where RAM connections are getting certain values. I have a W30x90 beam framed over the top of an HSS10x10x5/8 tube. The program is using only half the load that I applied and the values for bearing length (N) are inconsistent and much less than the width of the tube. I don't understand where the software is getting the value for N and why it's only using half the input load to compare with. Has anyone had similar issues with this particular connection?
If you are using v11.0.1.208, there was a defect in that version that might be applicable to your case for N values. Can you please upload your model to the following link? bentley.sharefile.com/r-rdb9868818794520a
