Modeling lifting lug reinforcement pad on flat plate
hi, all
i am a newbie to staadpro, my client want us to do the FEA on the lifting lug reinforcement pad for a pressure vessel,any body can tell me how to modelling the reinforcement pad on the flat cover? the flat cover size is 210x210x31.75mm thk, the reinforcement pad size is 60x150x12.7mm thk while the lifting lug size is 80x85x12.7mm thk.
thanks
  • You would probably get some valuable modeling ideas from the attached document.  It was prepared to give some modeling tips for a stiffened base plate, but some of the principles are probably applicable to your situation.
    Cheers,
    Chris
  • hi, Chirs
    thanks for your help
    i went through the materials, but i think this one is different from my case. my case is two parallel plate welding together in stead of perpendicular plates. Can you tell me how to modeling two parallel plate welding together? another issue, how to modeling two parallel beams at the same point.
    thanks.
  • If you can upload a detail drawing or sketch of the lug, I'll give you my thoughts. Chris
  • hi, chris please refer to the attached sketch for the reinforced lifting lug.
  • Try this...
    STAAD SPACE
    START JOB INFORMATION
    ENGINEER DATE 03-Dec-09
    END JOB INFORMATION
    INPUT WIDTH 79
    UNIT METER KN
    JOINT COORDINATES
    411 0.000607691 0.0519459 0; 412 0.00241229 0.0586808 0;
    413 0.00535898 0.0650001 0; 414 0.00935822 0.0707115 0;
    415 0.0142885 0.0756418 0; 416 0.02 0.079641 0;
    417 0.0263192 0.0825877 0; 418 0.0330541 0.0843923 0; 419 0.04 0.085 0;
    420 0.0469459 0.0843923 0; 421 0.0536808 0.0825877 0;
    422 0.06 0.079641 0; 423 0.0657115 0.0756418 0;
    424 0.0706418 0.0707115 0; 425 0.074641 0.0650001 0;
    426 0.0775877 0.0586808 0; 427 0.0793923 0.0519459 0;
    447 0.0203038 0.048473 0; 448 0.0212061 0.0518404 0;
    449 0.0226795 0.0549999 0; 450 0.0246791 0.0578557 0;
    451 0.0271442 0.0603209 0; 452 0.03 0.0623205 0;
    453 0.0331596 0.0637939 0; 454 0.036527 0.0646962 0;
    455 0.04 0.0650001 0; 456 0.043473 0.0646962 0;
    457 0.0468404 0.0637939 0; 458 0.05 0.0623205 0;
    459 0.0528558 0.0603209 0; 460 0.0553209 0.0578557 0;
    461 0.0573205 0.0549999 0; 462 0.0587939 0.0518404 0;
    463 0.0596962 0.048473 0; 483 0.0154974 0.0558932 0;
    485 0.0676997 0.0481325 0; 486 0.0343641 0.0731459 0;
    488 0.0477461 0.0721093 0; 489 0.0219308 0.0664564 0;
    490 0.0616528 0.0615667 0; 495 0.0574097 0.0676839 0;
    498 0.0155094 0.0641639 0; 499 0.0693525 0.0560664 0;
    500 0.00997798 0.050405 0; 502 0.0396484 0.0761336 0;
    504 0.0284101 0.0741303 0; 507 0.0517939 0.0737209 0;
    509 0.0294167 0.0670573 0; 511 0.0618943 0.0536646 0;
    512 0.0225685 0.0600134 0; 516 0.0543771 0.0643332 0;
    520 0.0633833 0.0652049 0; 521 0.0693457 0.0625516 0;
    522 0.0121972 0.0594417 0; 523 0.00835493 0.0567975 0;
    528 0.0694168 0.0521157 0; 529 0.0190234 0.0688527 0;
    530 0.0222064 0.074349 0; 531 0.0583527 0.0590219 0;
    532 0.0469438 0.0675076 0; 533 0.0635795 0.0476691 0;
    535 0.0360282 0.0681131 0; 537 0.0254212 0.0629041 0;
    539 0.0188743 0.0552714 0; 545 0.005 0.0468909 0;
    547 0.0346719 0.0794097 0; 548 0.0451932 0.0788276 0;
    549 0.0743384 0.0479928 0; 551 0.0303159 0.0781642 0;
    554 0.0573352 0.0750389 0; 555 0.0625349 0.0713668 0;
    557 0.0497185 0.078264 0; 559 0.0501998 0.0688237 0;
    560 0.0501569 0.0651683 0; 564 0.0419184 0.0697241 0;
    566 0.015916 0.0511144 0; 567 0.0722115 0.0598738 0;
    568 0.00589527 0.0524669 0; 569 0.0677386 0.066601 0;
    572 0.0247084 0.0779997 0; 578 0.0664654 0.0530219 0;
    580 0.0195314 0.0632565 0; 582 0.0662686 0.059463 0;
    584 0.0181184 0.0726928 0; 585 0.017 0.0593889 0;
    587 0.00783841 0.0610626 0; 589 0.0244479 0.0706706 0;
    592 0.0547129 0.0779932 0; 594 0.01185 0.0542649 0;
    598 0.0146047 0.0691116 0; 599 0.010914 0.0645469 0;
    602 0.073357 0.0566586 0; 604 0.08 0.0464062 0;
    605 0.0744046 0.0520308 0; 1009 -4.3582e-009 0 0; 1010 0.005 0 0;
    1011 0.01 0 0; 1012 0.015 0 0; 1013 0.02 0 0; 1014 0.025 0 0;
    1015 0.03 0 0; 1016 0.035 0 0; 1017 0.04 0 0; 1018 0.045 0 0;
    1019 0.05 0 0; 1020 0.055 0 0; 1021 0.06 0 0; 1022 0.065 0 0;
    1023 0.07 0 0; 1024 0.075 0 0; 1025 0.08 0 0; 1026 0.08 0.005 0;
    1027 0.08 0.00999999 0; 1028 0.08 0.015 0; 1029 0.08 0.02 0;
    1030 0.08 0.025 0; 1031 0.08 0.03 0; 1032 0.08 0.035 0;
    1033 0.08 0.04 0; 1034 0.08 0.045 0; 1066 -3.94824e-009 0.045 0;
    1067 -5.09207e-009 0.04 0; 1068 -6.23589e-009 0.035 0;
    1069 -6.07249e-009 0.03 0; 1070 -3.5336e-010 0.025 0;
    1071 -2.80442e-009 0.02 0; 1072 -2.64101e-009 0.015 0;
    1073 -2.13037e-009 0.00999999 0; 1074 -4.58143e-009 0.005 0;
    1075 0.06 0.045 0; 1093 0.02 0.045 0; 1094 0.0203038 0.041527 0;
    1095 0.0212061 0.0381596 0; 1096 0.0226795 0.035 0;
    1097 0.0246791 0.0321442 0; 1098 0.0271442 0.0296791 0;
    1099 0.03 0.0276795 0; 1100 0.0331596 0.0262061 0;
    1101 0.036527 0.0253038 0; 1102 0.04 0.025 0; 1103 0.043473 0.0253038 0;
    1104 0.0468404 0.0262061 0; 1105 0.05 0.0276795 0;
    1106 0.0528558 0.0296791 0; 1107 0.0553209 0.0321442 0;
    1108 0.0573205 0.035 0; 1109 0.0587939 0.0381596 0;
    1110 0.0596962 0.041527 0; 1111 0.0659525 0.0148934 0;
    1112 0.0140492 0.0148934 0; 1115 0.054265 0.0137001 0;
    1116 0.0257372 0.0137001 0; 1117 0.012244 0.0249646 0;
    1118 0.0677582 0.0249646 0; 1119 0.0447558 0.0129004 0;
    1128 0.0351652 0.0088672 0; 1129 0.0111511 0.0327082 0;
    1130 0.0688512 0.0327082 0; 1131 0.0696176 0.0409028 0;
    1132 0.0112287 0.0404161 0; 1133 0.0582936 0.0227815 0;
    1134 0.0217095 0.0227815 0; 1135 0.00801752 0.00829816 0;
    1136 0.0719847 0.00829816 0; 1142 0.0199298 0.0095315 0;
    1143 0.0600731 0.0095315 0; 1144 0.0329339 0.0159404 0;
    1145 0.0390785 0.0179529 0; 1146 0.00876552 0.0199529 0;
    1147 0.0712374 0.0199529 0; 1148 0.00790096 0.0458587 0;
    1149 0.0729541 0.0464627 0; 1152 0.0496743 0.0088672 0;
    1153 0.0478328 0.0188226 0; 1156 0.0280632 0.0221397 0;
    1157 0.0303017 0.00752282 0; 1158 0.0143169 0.0059436 0;
    1159 0.0656865 0.0059436 0; 1160 0.0399745 0.00725621 0;
    1163 0.0601338 0.0307031 0; 1164 0.0198686 0.0307031 0;
    1165 0.020832 0.0167735 0; 1166 0.059227 0.0163753 0;
    1175 0.00559551 0.0144174 0; 1176 0.0744078 0.0144174 0;
    1177 0.0549165 0.00613326 0; 1179 0.0168386 0.046 0;
    1180 0.0523056 0.022688 0; 1183 0.00694439 0.0366011 0;
    1184 0.0732771 0.0365121 0; 1185 0.00779952 0.0292245 0;
    1186 0.0722036 0.0292245 0; 1187 0.0250782 0.00568515 0;
    1188 0.0663229 0.036933 0; 1189 0.0137874 0.036838 0;
    1196 0.0448837 0.00537485 0; 1197 0.00552285 0.024726 0;
    1198 0.0744808 0.024726 0; 1203 0.0340556 0.0224893 0;
    1204 0.043725 0.0202866 0; 1205 0.0175874 0.0254324 0;
    1206 0.0622545 0.0253321 0; 1207 0.0155987 0.0189947 0;
    1208 0.0644056 0.0189947 0; 1217 0.00581248 0.0424552 0;
    1218 0.0741911 0.0424552 0; 1227 0.00434035 0.0044331 0;
    1228 0.075662 0.0044331 0; 1229 0.0412704 0.0127035 0;
    1230 0.0570951 0.0277214 0; 1231 0.0229084 0.0277214 0;
    1232 0.012129 0.00971204 0; 1233 0.0678751 0.00971204 0;
    1235 0.00433432 0.0311083 0; 1236 0.0745677 0.0313887 0;
    1237 0.055359 0.0178381 0; 1240 0.0619205 0.00515878 0;
    1241 0.018358 0.00566572 0; 1242 0.0358562 0.0128652 0;
    1243 0.0247677 0.0176553 0; 1244 0.0295064 0.0123938 0;
    1245 0.038536 0.0227525 0; 1246 0.0613487 0.0356895 0;
    1247 0.0187702 0.0356615 0; 1248 0.0632234 0.0418097 0;
    1249 0.0167803 0.0418098 0; 1252 0.00478819 0.0181237 0;
    1253 0.0752156 0.0181237 0; 1254 0.0181606 0.0138503 0;
    1255 0.0618439 0.0138503 0; 1256 0.0107792 0.00474763 0;
    1257 0.0692243 0.00474763 0; 1260 0.051531 0.00500059 0;
    1261 0.01378 0.0279411 0; 1262 0.0662245 0.0279411 0;
    1263 0.0705331 0.0164215 0; 1264 0.00947119 0.0164215 0;
    1265 0.0508542 0.0133902 0; 1266 0.00453885 0.0109055 0;
    1267 0.0754646 0.0109055 0; 1272 0.0235827 0.00963932 0;
    1273 0.0367141 0.00537485 0; 1278 0.0144588 0.0320077 0;
    1280 0.0655463 0.0320077 0; 1282 0.0564188 0.00978869 0;
    1285 0.0493568 0.024206 0; 1286 0.0284878 0.0253286 0;
    1287 0.028437 0.0185844 0; 1288 0.0352047 0.0188001 0;
    1289 0.00433194 0.039553 0; 1290 0.075672 0.039553 0;
    1291 0.0517212 0.0266824 0; 1292 0.0284609 0.00440305 0;
    1293 0.0333925 0.00325972 0; 1297 0.0124575 0.0454708 0;
    1298 0.0589463 0.00376445 0; 1299 0.0152625 0.02337 0;
    1300 0.0647427 0.02337 0; 1305 0.0210548 0.00361508 0;
    1306 0.0432054 0.00851083 0; 1307 0.0035069 0.0288453 0;
    1308 0.0764972 0.0288453 0; 1311 0.0416202 0.00421077 0;
    1318 0.0488056 0.00345892 0; 1323 0.0520959 0.0193765 0;
    1324 0.0457014 0.0169301 0; 1325 0.0632646 0.0110316 0;
    1326 0.0167408 0.0110316 0; 1329 0.0034382 0.0209501 0;
    1330 0.0765659 0.0209501 0; 1331 0.0711593 0.0232148 0;
    1332 0.00884525 0.0232148 0; 1334 0.0420176 0.0158624 0;
    1338 0.00906635 0.0135173 0; 1339 0.0709392 0.0135173 0;
    1340 0.0224945 0.0123969 0; 1341 0.0277979 0.00985229 0;
    1344 0.0248478 0.0208591 0; 1345 0.0253875 0.0250269 0;
    1346 0.00837433 0.0030607 0; 1347 0.0716293 0.0030607 0;
    1348 0.0607351 0.0196341 0; 1349 0.0192703 0.0196341 0;
    1350 0.0575099 0.0124467 0; 1354 0.0106055 0.0381212 0;
    1355 0.0702916 0.0369601 0; 1358 0.0558988 0.0243972 0;
    1359 0.01321 0.0207728 0; 1360 0.0667958 0.0207728 0;
    1362 0.00296093 0.00844657 0; 1363 0.0770427 0.00844657 0;
    1366 0.00405921 0.0343379 0; 1367 0.0759448 0.0343379 0;
    1373 0.0534534 0.0107857 0; 1375 0.0454856 0.0225856 0;
    1378 0.0458793 0.0100932 0; 1381 0.0137509 0.0419801 0;
    1382 0.0667967 0.0427278 0; 1386 0.0391842 0.0108235 0;
    1387 0.00996494 0.0442788 0; 1388 0.0700402 0.0442788 0;
    1393 0.0388855 0.014389 0; 1394 0.00428838 0.0446393 0;
    1397 0.0579793 0.00647682 0; 1398 0.067761 0.0173628 0;
    1399 0.0122445 0.0173628 0; 1401 0.0325667 0.0199582 0;
    1404 0.0109113 0.0299581 0; 1405 0.0690937 0.0299581 0;
    1406 0.0722286 0.0335739 0; 1407 0.00777622 0.0335739 0;
    1409 0.0329541 0.00655031 0; 1410 0.0316587 0.00959492 0;
    1411 0.0334813 0.0126876 0; 1412 0.0562882 0.00329965 0;
    1414 0.0727048 0.0388866 0; 1415 0.00730001 0.0388866 0;
    1416 0.0471045 0.0144072 0; 1417 0.0164913 0.0381467 0;
    1418 0.0635138 0.0381467 0; 1425 0.0404473 0.0203309 0;
    1430 0.0766221 0.0448679 0; 1431 0.0624144 0.0326948 0;
    1433 0.0175909 0.0326948 0; 1438 0.0682561 0.0127079 0;
    1439 0.0117493 0.0127079 0; 1447 0.0477886 0.00590068 0;
    1450 0.023712 0.00310051 0; 1453 0.059151 0.0255511 0;
    1454 0.0208542 0.0255511 0; 1455 0.0545218 0.0216414 0;
    1456 0.0317604 0.023612 0; 1457 0.0774318 0.0414737 0;
    1458 0.0394456 0.00319564 0; 1463 0.0628075 0.0282649 0;
    1464 0.0171978 0.0282649 0; 1466 0.0703742 0.0258015 0;
    1467 0.00963071 0.0258015 0; 1469 0.0301412 0.0156454 0;
    1470 0.00301111 0.0261906 0; 1471 0.0769932 0.0261906 0;
    1473 0.00287463 0.0413975 0; 1476 0.0158011 0.00370121 0;
    1477 0.0666375 0.00356418 0; 1478 0.0612577 0.0219287 0;
    1479 0.0215235 0.00759566 0; 1480 0.0187485 0.0219287 0;
    1481 0.0639723 0.0452002 0; 1482 0.05 0 -0.03; 1483 0.055 0 -0.03;
    1484 0.06 0 -0.03; 1485 0.065 0 -0.03; 1486 0.07 0 -0.03;
    1487 0.075 0 -0.03; 1488 0.08 0 -0.03; 1489 0.085 0 -0.03;
    1490 0.09 0 -0.03; 1491 0.095 0 -0.03; 1492 0.1 0 -0.03;
    1493 0.105 0 -0.03; 1494 0.11 0 -0.03; 1495 0.115 0 -0.03;
    1496 -0.035 0 -0.025; 1497 -0.03 0 -0.025; 1498 -0.025 0 -0.025;
    1499 -0.02 0 -0.025; 1500 -0.015 0 -0.025; 1501 -0.01 0 -0.025;
    1502 -0.005 0 -0.025; 1503 0 0 -0.025; 1504 0.005 0 -0.025;
    1505 0.01 0 -0.025; 1506 0.015 0 -0.025; 1507 0.02 0 -0.025;
    1508 0.025 0 -0.025; 1509 0.03 0 -0.025; 1510 0.035 0 -0.025;
    1511 0.04 0 -0.025; 1512 0.045 0 -0.025; 1513 0.05 0 -0.025;
    1514 0.055 0 -0.025; 1515 0.06 0 -0.025; 1516 0.065 0 -0.025;
    1517 0.07 0 -0.025; 1518 0.075 0 -0.025; 1519 0.08 0 -0.025;
    1520 0.085 0 -0.025; 1521 0.09 0 -0.025; 1522 0.095 0 -0.025;
    1523 0.1 0 -0.025; 1524 0.105 0 -0.025; 1525 0.11 0 -0.025;
    1526 0.115 0 -0.025; 1527 -0.035 0 -0.02; 1528 -0.03 0 -0.02;
    1529 -0.025 0 -0.02; 1530 -0.02 0 -0.02; 1531 -0.015 0 -0.02;
    1532 -0.01 0 -0.02; 1533 -0.005 0 -0.02; 1534 0 0 -0.02;
    1535 0.005 0 -0.02; 1536 0.01 0 -0.02; 1537 0.015 0 -0.02;
    1538 0.02 0 -0.02; 1539 0.025 0 -0.02; 1540 0.03 0 -0.02;
    1541 0.035 0 -0.02; 1542 0.04 0 -0.02; 1543 0.045 0 -0.02;
    1544 0.05 0 -0.02; 1545 0.055 0 -0.02; 1546 0.06 0 -0.02;
    1547 0.065 0 -0.02; 1548 0.07 0 -0.02; 1549 0.075 0 -0.02;
    1550 0.08 0 -0.02; 1551 0.085 0 -0.02; 1552 0.09 0 -0.02;
    1553 0.095 0 -0.02; 1554 0.1 0 -0.02; 1555 0.105 0 -0.02;
    1556 0.11 0 -0.02; 1557 0.115 0 -0.02; 1558 -0.035 0 -0.015;
    1559 -0.03 0 -0.015; 1560 -0.025 0 -0.015; 1561 -0.02 0 -0.015;
    1562 -0.015 0 -0.015; 1563 -0.01 0 -0.015; 1564 -0.005 0 -0.015;
    1565 0 0 -0.015; 1566 0.005 0 -0.015; 1567 0.01 0 -0.015;
    1568 0.015 0 -0.015; 1569 0.02 0 -0.015; 1570 0.025 0 -0.015;
    1571 0.03 0 -0.015; 1572 0.035 0 -0.015; 1573 0.04 0 -0.015;
    1574 0.045 0 -0.015; 1575 0.05 0 -0.015; 1576 0.055 0 -0.015;
    1577 0.06 0 -0.015; 1578 0.065 0 -0.015; 1579 0.07 0 -0.015;
    1580 0.075 0 -0.015; 1581 0.08 0 -0.015; 1582 0.085 0 -0.015;
    1583 0.09 0 -0.015; 1584 0.095 0 -0.015; 1585 0.1 0 -0.015;
    1586 0.105 0 -0.015; 1587 0.11 0 -0.015; 1588 0.115 0 -0.015;
    1589 -0.035 0 -0.01; 1590 -0.03 0 -0.01; 1591 -0.025 0 -0.01;
    1592 -0.02 0 -0.01; 1593 -0.015 0 -0.01; 1594 -0.01 0 -0.01;
    1595 -0.005 0 -0.01; 1596 0 0 -0.01; 1597 0.005 0 -0.01;
    1598 0.01 0 -0.01; 1599 0.015 0 -0.01; 1600 0.02 0 -0.01;
    1601 0.025 0 -0.01; 1602 0.03 0 -0.01; 1603 0.035 0 -0.01;
    1604 0.04 0 -0.01; 1605 0.045 0 -0.01; 1606 0.05 0 -0.01;
    1607 0.055 0 -0.01; 1608 0.06 0 -0.01; 1609 0.065 0 -0.01;
    1610 0.07 0 -0.01; 1611 0.075 0 -0.01; 1612 0.08 0 -0.01;
    1613 0.085 0 -0.01; 1614 0.09 0 -0.01; 1615 0.095 0 -0.01;
    1616 0.1 0 -0.01; 1617 0.105 0 -0.01; 1618 0.11 0 -0.01;
    1619 0.115 0 -0.01; 1620 -0.035 0 -0.005; 1621 -0.03 0 -0.005;
    1622 -0.025 0 -0.005; 1623 -0.02 0 -0.005; 1624 -0.015 0 -0.005;
    1625 -0.01 0 -0.005; 1626 -0.005 0 -0.005; 1627 0 0 -0.005;
    1628 0.005 0 -0.005; 1629 0.01 0 -0.005; 1630 0.015 0 -0.005;
    1631 0.02 0 -0.005; 1632 0.025 0 -0.005; 1633 0.03 0 -0.005;
    1634 0.035 0 -0.005; 1635 0.04 0 -0.005; 1636 0.045 0 -0.005;
    1637 0.05 0 -0.005; 1638 0.055 0 -0.005; 1639 0.06 0 -0.005;
    1640 0.065 0 -0.005; 1641 0.07 0 -0.005; 1642 0.075 0 -0.005;
    1643 0.08 0 -0.005; 1644 0.085 0 -0.005; 1645 0.09 0 -0.005;
    1646 0.095 0 -0.005; 1647 0.1 0 -0.005; 1648 0.105 0 -0.005;
    1649 0.11 0 -0.005; 1650 0.115 0 -0.005; 1651 -0.035 0 0;
    1652 -0.03 0 0; 1653 -0.025 0 0; 1654 -0.02 0 0; 1655 -0.015 0 0;
    1656 -0.01 0 0; 1657 -0.005 0 0; 1675 0.085 0 0; 1676 0.09 0 0;
    1677 0.095 0 0; 1678 0.1 0 0; 1679 0.105 0 0; 1680 0.11 0 0;
    1681 0.115 0 0; 1682 -0.035 0 0.005; 1683 -0.03 0 0.005;
    1684 -0.025 0 0.005; 1685 -0.02 0 0.005; 1686 -0.015 0 0.005;
    1687 -0.01 0 0.005; 1688 -0.005 0 0.005; 1689 0 0 0.005;
    1690 0.00499999 0 0.005; 1691 0.01 0 0.005; 1692 0.015 0 0.005;
    1693 0.02 0 0.005; 1694 0.025 0 0.005; 1695 0.03 0 0.005;
    1696 0.035 0 0.005; 1697 0.04 0 0.005; 1698 0.045 0 0.005;
    1699 0.05 0 0.005; 1700 0.055 0 0.005; 1701 0.06 0 0.005;
    1702 0.065 0 0.005; 1703 0.07 0 0.005; 1704 0.075 0 0.005;
    1705 0.08 0 0.005; 1706 0.085 0 0.005; 1707 0.09 0 0.005;
    1708 0.095 0 0.005; 1709 0.1 0 0.005; 1710 0.105 0 0.005;
    1711 0.11 0 0.005; 1712 0.115 0 0.005; 1713 -0.035 0 0.01;
    1714 -0.03 0 0.01; 1715 -0.025 0 0.01; 1716 -0.02 0 0.01;
    1717 -0.015 0 0.01; 1718 -0.01 0 0.01; 1719 -0.005 0 0.01;
    1720 0 0 0.01; 1721 0.00499999 0 0.01; 1722 0.01 0 0.01;
    1723 0.015 0 0.01; 1724 0.02 0 0.01; 1725 0.025 0 0.01;
    1726 0.03 0 0.01; 1727 0.035 0 0.01; 1728 0.04 0 0.01;
    1729 0.045 0 0.01; 1730 0.05 0 0.01; 1731 0.055 0 0.01;
    1732 0.06 0 0.01; 1733 0.065 0 0.01; 1734 0.07 0 0.01;
    1735 0.075 0 0.01; 1736 0.08 0 0.01; 1737 0.085 0 0.01;
    1738 0.09 0 0.01; 1739 0.095 0 0.01; 1740 0.1 0 0.01; 1741 0.105 0 0.01;
    1742 0.11 0 0.01; 1743 0.115 0 0.01; 1744 -0.035 0 0.015;
    1745 -0.03 0 0.015; 1746 -0.025 0 0.015; 1747 -0.02 0 0.015;
    1748 -0.015 0 0.015; 1749 -0.01 0 0.015; 1750 -0.005 0 0.015;
    1751 0 0 0.015; 1752 0.00499999 0 0.015; 1753 0.01 0 0.015;
    1754 0.015 0 0.015; 1755 0.02 0 0.015; 1756 0.025 0 0.015;
    1757 0.03 0 0.015; 1758 0.035 0 0.015; 1759 0.04 0 0.015;
    1760 0.045 0 0.015; 1761 0.05 0 0.015; 1762 0.055 0 0.015;
    1763 0.06 0 0.015; 1764 0.065 0 0.015; 1765 0.07 0 0.015;
    1766 0.075 0 0.015; 1767 0.08 0 0.015; 1768 0.085 0 0.015;
    1769 0.09 0 0.015; 1770 0.095 0 0.015; 1771 0.1 0 0.015;
    1772 0.105 0 0.015; 1773 0.11 0 0.015; 1774 0.115 0 0.015;
    1775 -0.035 0 0.02; 1776 -0.03 0 0.02; 1777 -0.025 0 0.02;
    1778 -0.02 0 0.02; 1779 -0.015 0 0.02; 1780 -0.01 0 0.02;
    1781 -0.005 0 0.02; 1782 0 0 0.02; 1783 0.00499999 0 0.02;
    1784 0.01 0 0.02; 1785 0.015 0 0.02; 1786 0.02 0 0.02;
    1787 0.025 0 0.02; 1788 0.03 0 0.02; 1789 0.035 0 0.02;
    1790 0.04 0 0.02; 1791 0.045 0 0.02; 1792 0.05 0 0.02;
    1793 0.055 0 0.02; 1794 0.06 0 0.02; 1795 0.065 0 0.02;
    1796 0.07 0 0.02; 1797 0.075 0 0.02; 1798 0.08 0 0.02;
    1799 0.085 0 0.02; 1800 0.09 0 0.02; 1801 0.095 0 0.02; 1802 0.1 0 0.02;
    1803 0.105 0 0.02; 1804 0.11 0 0.02; 1805 0.115 0 0.02;
    1806 -0.035 0 0.025; 1807 -0.03 0 0.025; 1808 -0.025 0 0.025;
    1809 -0.02 0 0.025; 1810 -0.015 0 0.025; 1811 -0.01 0 0.025;
    1812 -0.005 0 0.025; 1813 0 0 0.025; 1814 0.00499999 0 0.025;
    1815 0.01 0 0.025; 1816 0.015 0 0.025; 1817 0.02 0 0.025;
    1818 0.025 0 0.025; 1819 0.03 0 0.025; 1820 0.035 0 0.025;
    1821 0.04 0 0.025; 1822 0.045 0 0.025; 1823 0.05 0 0.025;
    1824 0.055 0 0.025; 1825 0.06 0 0.025; 1826 0.065 0 0.025;
    1827 0.07 0 0.025; 1828 0.075 0 0.025; 1829 0.08 0 0.025;
    1830 0.085 0 0.025; 1831 0.09 0 0.025; 1832 0.095 0 0.025;
    1833 0.1 0 0.025; 1834 0.105 0 0.025; 1835 0.11 0 0.025;
    1836 0.115 0 0.025; 1837 -0.035 0 0.03; 1838 -0.03 0 0.03;
    1839 -0.025 0 0.03; 1840 -0.02 0 0.03; 1841 -0.015 0 0.03;
    1842 -0.01 0 0.03; 1843 -0.005 0 0.03; 1844 0 0 0.03;
    1845 0.00499999 0 0.03; 1846 0.01 0 0.03; 1847 0.015 0 0.03;
    1848 0.02 0 0.03; 1849 0.025 0 0.03; 1850 0.03 0 0.03;
    1851 0.035 0 0.03; 1852 0.04 0 0.03; 1853 0.045 0 0.03;
    1854 0.05 0 0.03; 1855 0.055 0 0.03; 1856 0.06 0 0.03;
    1857 0.065 0 0.03; 1858 0.07 0 0.03; 1859 0.075 0 0.03;
    1860 0.08 0 0.03; 1861 0.085 0 0.03; 1862 0.09 0 0.03;
    1863 0.095 0 0.03; 1864 0.1 0 0.03; 1865 0.105 0 0.03; 1866 0.11 0 0.03;
    1867 0.115 0 0.03; 1868 0.045 0 -0.03; 1869 0.04 0 -0.03;
    1870 0.035 0 -0.03; 1871 0.03 0 -0.03; 1872 0.025 0 -0.03;
    1873 0.02 0 -0.03; 1874 0.015 0 -0.03; 1875 0.01 0 -0.03;
    1876 0.005 0 -0.03; 1877 -3.72529e-009 0 -0.03;
    1878 -0.00500001 0 -0.03; 1879 -0.01 0 -0.03; 1880 -0.015 0 -0.03;
    1881 -0.02 0 -0.03; 1882 -0.025 0 -0.03; 1883 -0.03 0 -0.03;
    1884 -0.035 0 -0.03;
    ELEMENT INCIDENCES SHELL
    717 523 522 587; 718 512 537 580; 719 545 500 568; 721 530 416 584;
    722 529 489 589; 735 509 489 537; 736 486 504 509; 737 509 504 589;
    738 512 451 537; 739 529 498 580; 740 498 598 599; 741 523 412 568;
    742 535 455 564; 743 502 419 547; 744 456 532 564; 745 502 486 564;
    746 548 502 564; 747 548 488 557; 748 516 559 560; 749 516 495 559;
    750 507 495 554; 751 495 490 520; 752 490 495 516; 753 516 459 531;
    754 422 554 555; 755 521 425 569; 756 511 578 582; 757 511 490 531;
    758 511 533 578; 759 511 463 533; 760 520 490 582; 761 528 485 549;
    763 1481 485 533; 785 448 539 566; 786 1297 1179 566; 787 500 1297 566;
    791 539 483 566; 792 512 580 585; 795 567 499 602; 796 533 485 578;
    797 547 418 551; 798 486 509 535; 801 419 502 548; 802 532 488 564;
    803 529 584 598; 804 537 489 580; 805 554 495 555; 806 490 516 531;
    814 1179 447 566; 815 557 507 592; 816 495 507 559; 821 598 414 599;
    822 539 512 585; 823 528 499 578; 824 425 521 567; 825 522 523 594;
    826 411 1066 545; 829 419 418 547; 830 486 535 564; 833 486 547 551;
    834 416 530 572; 839 420 548 557; 840 532 457 560; 843 452 453 509;
    844 509 453 535; 847 461 462 511; 848 462 463 511; 849 449 450 512;
    850 450 451 512; 857 458 459 516; 858 459 460 531; 865 521 520 582;
    866 424 423 555; 867 567 521 582; 868 425 424 569; 869 412 523 587;
    870 522 483 585; 871 412 411 568; 872 523 568 594; 882 427 426 602;
    883 530 529 589; 884 584 415 598; 885 504 551 572; 886 416 415 584;
    887 460 461 531; 888 461 511 531; 889 456 457 532; 890 559 532 560;
    891 463 1075 533; 892 1075 1481 533; 895 453 454 535; 896 454 455 535;
    899 451 452 537; 900 452 509 537; 903 448 449 539; 904 449 512 539;
    908 1093 447 1179; 919 418 417 551; 920 486 502 547; 921 488 507 557;
    922 420 419 548; 924 604 427 549; 927 551 417 572; 928 504 486 551;
    933 495 520 555; 934 422 421 592; 935 555 520 569; 936 423 422 555;
    939 507 554 592; 940 421 420 557; 943 507 488 559; 944 488 532 559;
    945 457 458 560; 946 458 516 560; 953 455 456 564; 954 488 548 564;
    957 447 448 566; 958 566 483 594; 959 499 528 602; 960 426 425 567;
    961 411 545 568; 962 568 500 594; 963 424 555 569; 964 520 521 569;
    969 417 416 572; 970 530 504 572; 981 485 528 578; 982 578 499 582;
    985 489 529 580; 986 580 498 585; 989 490 511 582; 990 499 567 582;
    993 415 414 598; 994 529 530 584; 995 498 522 585; 996 483 539 585;
    999 587 522 599; 1000 413 412 587; 1003 489 509 589; 1004 504 530 589;
    1009 554 422 592; 1010 421 557 592; 1013 500 566 594; 1014 483 522 594;
    1021 414 413 599; 1022 498 529 598; 1023 413 587 599; 1024 522 498 599;
    1030 426 567 602; 1031 1394 545 1066; 1032 1148 545 1394;
    1033 1148 500 545; 1034 1297 500 1148; 1041 528 605 602;
    1042 605 427 602; 1043 528 549 605; 1044 549 427 605;
    1405 1467 1197 1332; 1406 1454 1231 1164; 1407 1227 1074 1009;
    1408 1359 1299 1117; 1409 1366 1069 1235; 1410 1414 1290 1218;
    1411 1264 1252 1175; 1412 1326 1232 1158; 1413 1362 1135 1266;
    1414 1346 1256 1135; 1415 1248 1481 1075; 1416 1326 1158 1241;
    1417 1393 1288 1242; 1418 1409 1293 1273; 1419 1358 1230 1291;
    1420 1478 1300 1206; 1421 1412 1177 1260; 1427 1467 1117 1261;
    1428 1418 1188 1382; 1433 1433 1247 1189; 1437 1231 1097 1164;
    1438 1456 1401 1203; 1439 1287 1243 1116; 1447 1341 1116 1272;
    1448 1288 1245 1203; 1449 1480 1207 1349; 1454 1367 1032 1290;
    1459 1373 1177 1282; 1460 1355 1131 1188; 1461 1406 1186 1236;
    1462 1308 1236 1186; 1463 1466 1331 1198; 1464 1228 1024 1025;
    1465 1348 1166 1208; 1466 1463 1262 1280; 1467 1263 1176 1253;
    1468 1347 1136 1257; 1469 1463 1206 1262; 1470 1325 1111 1255;
    1471 1267 1028 1176; 1472 1363 1267 1136; 1473 1339 1176 1263;
    1474 1479 1142 1241; 1475 1375 1153 1285; 1476 1393 1242 1386;
    1477 1350 1255 1166; 1478 1334 1119 1324; 1479 1416 1153 1324;
    1480 1311 1018 1196; 1491 1473 1289 1217; 1502 1417 1247 1095;
    1505 1381 1179 1297; 1506 1354 1129 1189; 1507 1477 1159 1240;
    1508 1463 1163 1453; 1509 1476 1158 1256; 1510 1252 1072 1175;
    1515 1311 1196 1306; 1516 1323 1180 1285; 1517 1401 1144 1288;
    1518 1292 1157 1187; 1519 1307 1185 1235; 1520 1464 1278 1261;
    1521 1280 1130 1188; 1522 1330 1147 1253; 1523 1458 1311 1160;
    1524 1324 1153 1204; 1541 1293 1292 1015; 1542 1469 1244 1411;
    1543 1415 1132 1217; 1544 1247 1164 1096; 1545 1418 1382 1248;
    1546 1406 1405 1186; 1549 1387 1148 1217; 1550 1381 1132 1189;
    1551 1323 1115 1237; 1552 1230 1163 1107; 1553 1345 1344 1156;
    1554 1344 1165 1243; 1555 1346 1227 1010; 1556 1266 1175 1072;
    1557 1363 1228 1026; 1558 1477 1023 1257; 1569 1476 1013 1241;
    1570 1340 1243 1165; 1571 1325 1240 1159; 1572 1412 1021 1298;
    1573 1349 1165 1344; 1574 1288 1145 1245; 1575 1425 1204 1103;
    1576 1386 1242 1128; 1577 1439 1399 1264; 1578 1470 1070 1329;
    1579 1253 1176 1028; 1580 1398 1147 1360; 1584 1457 1034 1430;
    1589 1373 1152 1177; 1590 1318 1196 1018; 1591 1291 1105 1285;
    1592 1323 1153 1265; 1597 1345 1134 1344; 1598 1456 1099 1286;
    1599 1450 1014 1292; 1600 1341 1272 1187; 1601 1256 1011 1012;
    1602 1256 1158 1232; 1603 1257 1233 1159; 1604 1240 1021 1022;
    1605 1378 1306 1196; 1606 1458 1273 1016; 1611 1163 1108 1107;
    1612 1246 1109 1108; 1613 1164 1097 1096; 1614 1231 1098 1097;
    1615 1340 1142 1272; 1616 1254 1165 1207; 1617 1255 1208 1166;
    1618 1455 1133 1358; 1635 1338 1175 1266; 1636 1252 1071 1072;
    1637 1267 1027 1028; 1638 1339 1233 1136; 1639 1397 1298 1240;
    1640 1260 1019 1020; 1644 1249 1094 1093; 1645 1291 1285 1180;
    1646 1348 1133 1237; 1651 1407 1235 1185; 1652 1289 1067 1068;
    1653 1367 1236 1031; 1654 1355 1188 1130; 1655 1467 1185 1197;
    1656 1307 1197 1185; 1657 1471 1031 1308; 1658 1466 1405 1262;
    1659 1450 1305 1013; 1660 1479 1305 1187; 1661 1463 1280 1431;
    1662 1418 1110 1109; 1663 1417 1094 1249; 1664 1407 1129 1354;
    1677 1447 1318 1260; 1678 1311 1017 1018; 1679 1329 1252 1146;
    1680 1470 1307 1069; 1681 1330 1029 1030; 1682 1331 1330 1198;
    1691 1203 1101 1100; 1692 1245 1101 1203; 1693 1425 1102 1245;
    1694 1375 1285 1104; 1695 1480 1299 1207; 1696 1299 1205 1261;
    1697 1478 1348 1208; 1698 1453 1163 1230; 1699 1399 1207 1359;
    1700 1359 1207 1299; 1701 1360 1118 1300; 1702 1255 1111 1208;
    1719 1415 1217 1289; 1720 1473 1394 1066; 1721 1457 1430 1218;
    1722 1388 1131 1218; 1739 1227 1009 1010; 1740 1362 1073 1074;
    1741 1228 1025 1026; 1742 1347 1023 1024; 1743 1334 1324 1204;
    1744 1306 1119 1229; 1745 1453 1230 1358; 1746 1230 1107 1106;
    1747 1345 1286 1098; 1748 1454 1345 1231; 1749 1338 1266 1135;
    1750 1326 1254 1112; 1751 1438 1339 1263; 1752 1257 1136 1233;
    1755 1366 1068 1069; 1756 1407 1366 1235; 1757 1406 1236 1367;
    1758 1308 1031 1236; 1759 1350 1166 1237; 1760 1323 1265 1115;
    1765 1298 1021 1240; 1766 1325 1143 1240; 1767 1479 1241 1305;
    1768 1476 1012 1013; 1769 1411 1410 1128; 1770 1288 1144 1242;
    1771 1344 1243 1287; 1772 1340 1116 1243; 1773 1469 1287 1116;
    1774 1411 1244 1410; 1775 1245 1102 1101; 1776 1425 1103 1102;
    1777 1246 1108 1163; 1778 1418 1248 1110; 1779 1247 1096 1095;
    1780 1464 1433 1278; 1781 1248 1075 1110; 1783 1249 1093 1179;
    1784 1417 1095 1094; 1789 1329 1071 1252; 1790 1264 1146 1252;
    1791 1331 1147 1330; 1792 1253 1028 1029; 1793 1326 1142 1254;
    1794 1254 1207 1112; 1795 1438 1111 1325; 1796 1350 1282 1143;
    1797 1346 1011 1256; 1798 1256 1232 1135; 1799 1347 1228 1136;
    1800 1477 1022 1023; 1805 1318 1019 1260; 1806 1260 1177 1152;
    1807 1467 1261 1404; 1808 1404 1261 1278; 1809 1405 1280 1262;
    1810 1300 1118 1262; 1811 1398 1360 1208; 1812 1263 1253 1147;
    1813 1399 1359 1146; 1814 1439 1264 1338; 1815 1373 1115 1265;
    1816 1378 1152 1265; 1817 1362 1227 1135; 1818 1266 1072 1073;
    1819 1363 1027 1267; 1820 1339 1136 1267; 1829 1340 1254 1142;
    1830 1341 1244 1116; 1831 1409 1157 1292; 1832 1273 1160 1128;
    1841 1278 1189 1129; 1842 1433 1189 1278; 1845 1431 1280 1188;
    1846 1405 1130 1280; 1849 1373 1282 1350; 1850 1397 1143 1282;
    1855 1375 1204 1153; 1856 1285 1105 1104; 1857 1286 1099 1098;
    1858 1456 1100 1099; 1859 1456 1156 1401; 1860 1469 1401 1287;
    1861 1393 1145 1288; 1862 1469 1144 1401; 1863 1366 1183 1289;
    1864 1473 1217 1394; 1865 1290 1032 1033; 1866 1414 1184 1290;
    1867 1291 1106 1105; 1868 1291 1230 1106; 1869 1409 1292 1293;
    1870 1292 1014 1015; 1871 1293 1016 1273; 1872 1293 1015 1016;
    1879 1381 1249 1179; 1880 1387 1381 1297; 1881 1412 1020 1021;
    1882 1412 1298 1397; 1883 1299 1261 1117; 1884 1480 1454 1205;
    1885 1300 1262 1206; 1886 1360 1331 1118; 1895 1450 1187 1305;
    1896 1305 1241 1013; 1897 1386 1160 1306; 1898 1378 1119 1306;
    1899 1470 1197 1307; 1900 1307 1235 1069; 1901 1471 1030 1031;
    1902 1308 1186 1198; 1907 1458 1017 1311; 1908 1311 1306 1160;
    1921 1318 1018 1019; 1922 1447 1196 1318; 1931 1323 1285 1153;
    1932 1455 1180 1323; 1933 1416 1265 1153; 1934 1334 1229 1119;
    1935 1325 1159 1233; 1936 1325 1255 1143; 1937 1326 1241 1142;
    1938 1439 1232 1326; 1943 1329 1070 1071; 1944 1332 1197 1329;
    1945 1471 1198 1330; 1946 1330 1253 1029; 1947 1360 1147 1331;
    1948 1466 1118 1331; 1949 1359 1117 1332; 1950 1332 1329 1146;
    1953 1393 1229 1334; 1954 1425 1145 1334; 1961 1338 1135 1232;
    1962 1338 1264 1175; 1963 1339 1267 1176; 1964 1438 1233 1339;
    1965 1340 1165 1254; 1966 1340 1272 1116; 1967 1410 1244 1341;
    1968 1341 1187 1157; 1973 1454 1134 1345; 1974 1344 1287 1156;
    1975 1345 1098 1231; 1976 1345 1156 1286; 1977 1346 1010 1011;
    1978 1346 1135 1227; 1979 1347 1024 1228; 1980 1347 1257 1023;
    1981 1348 1237 1166; 1982 1478 1133 1348; 1983 1349 1344 1134;
    1984 1349 1207 1165; 1985 1350 1237 1115; 1986 1350 1143 1255;
    1993 1415 1183 1354; 1994 1354 1189 1132; 1995 1414 1131 1355;
    1996 1406 1184 1355; 2001 1455 1237 1133; 2002 1358 1291 1180;
    2003 1399 1112 1207; 2004 1359 1332 1146; 2005 1398 1263 1147;
    2006 1360 1300 1208; 2009 1362 1074 1227; 2010 1362 1266 1073;
    2011 1363 1026 1027; 2012 1363 1136 1228; 2017 1366 1289 1068;
    2018 1407 1183 1366; 2019 1367 1290 1184; 2020 1367 1031 1032;
    2031 1373 1265 1152; 2032 1373 1350 1115; 2035 1375 1103 1204;
    2036 1375 1104 1103; 2041 1416 1119 1378; 2042 1447 1152 1378;
    2047 1417 1249 1381; 2048 1387 1132 1381; 2049 1382 1188 1131;
    2050 1382 1481 1248; 2057 1386 1306 1229; 2058 1386 1128 1160;
    2059 1387 1217 1132; 2061 1388 1218 1149; 2062 1388 1382 1131;
    2071 1393 1334 1145; 2072 1393 1386 1229; 2074 1394 1217 1148;
    2079 1397 1282 1177; 2080 1397 1240 1143; 2081 1438 1263 1398;
    2082 1398 1208 1111; 2083 1439 1112 1399; 2084 1399 1146 1264;
    2087 1401 1156 1287; 2088 1401 1288 1203; 2093 1407 1185 1404;
    2094 1404 1278 1129; 2095 1406 1130 1405; 2096 1466 1186 1405;
    2097 1406 1355 1130; 2098 1406 1367 1184; 2099 1407 1354 1183;
    2100 1407 1404 1129; 2103 1410 1157 1409; 2104 1409 1273 1128;
    2105 1410 1409 1128; 2106 1410 1341 1157; 2107 1411 1242 1144;
    2108 1411 1128 1242; 2109 1412 1260 1020; 2110 1412 1397 1177;
    2113 1414 1355 1184; 2114 1414 1218 1131; 2115 1415 1354 1132;
    2116 1415 1289 1183; 2117 1416 1378 1265; 2118 1416 1324 1119;
    2119 1417 1189 1247; 2120 1417 1381 1189; 2121 1418 1246 1188;
    2122 1418 1109 1246; 2135 1425 1334 1204; 2136 1425 1245 1145;
    2145 1457 1033 1034; 2146 1430 1149 1218; 2147 1431 1246 1163;
    2148 1431 1188 1246; 2151 1433 1164 1247; 2152 1464 1164 1433;
    2161 1438 1325 1233; 2162 1438 1398 1111; 2163 1439 1326 1112;
    2164 1439 1338 1232; 2179 1447 1378 1196; 2180 1447 1260 1152;
    2185 1450 1292 1187; 2186 1450 1013 1014; 2191 1478 1206 1453;
    2192 1453 1358 1133; 2193 1480 1134 1454; 2194 1464 1205 1454;
    2195 1455 1323 1237; 2196 1455 1358 1180; 2197 1456 1286 1156;
    2198 1456 1203 1100; 2199 1457 1290 1033; 2200 1457 1218 1290;
    2201 1458 1016 1017; 2202 1458 1160 1273; 2211 1463 1453 1206;
    2212 1463 1431 1163; 2213 1464 1454 1164; 2214 1464 1261 1205;
    2217 1466 1262 1118; 2218 1466 1198 1186; 2219 1467 1404 1185;
    2220 1467 1332 1117; 2223 1469 1411 1144; 2224 1469 1116 1244;
    2225 1470 1329 1197; 2226 1470 1069 1070; 2227 1471 1330 1030;
    2228 1471 1308 1198; 2231 1473 1067 1289; 2232 1473 1066 1067;
    2237 1476 1256 1012; 2238 1476 1241 1158; 2239 1477 1240 1022;
    2240 1477 1257 1159; 2241 1478 1453 1133; 2242 1478 1208 1300;
    2243 1479 1272 1142; 2244 1479 1187 1272; 2245 1480 1205 1299;
    2246 1480 1349 1134; 2247 1297 1148 1387; 2248 1382 485 1481;
    2249 1382 1388 485; 2250 1388 1149 485; 2251 485 1149 549;
    2252 1149 1430 549; 2253 1034 604 1430; 2254 1430 604 549;
    2255 1884 1883 1497 1496; 2256 1883 1882 1498 1497;
    2257 1882 1881 1499 1498; 2258 1881 1880 1500 1499;
    2259 1880 1879 1501 1500; 2260 1879 1878 1502 1501;
    2261 1878 1877 1503 1502; 2262 1877 1876 1504 1503;
    2263 1876 1875 1505 1504; 2264 1875 1874 1506 1505;
    2265 1874 1873 1507 1506; 2266 1873 1872 1508 1507;
    2267 1872 1871 1509 1508; 2268 1871 1870 1510 1509;
    2269 1870 1869 1511 1510; 2270 1869 1868 1512 1511;
    2271 1868 1482 1513 1512; 2272 1482 1483 1514 1513;
    2273 1483 1484 1515 1514; 2274 1484 1485 1516 1515;
    2275 1485 1486 1517 1516; 2276 1486 1487 1518 1517;
    2277 1487 1488 1519 1518; 2278 1488 1489 1520 1519;
    2279 1489 1490 1521 1520; 2280 1490 1491 1522 1521;
    2281 1491 1492 1523 1522; 2282 1492 1493 1524 1523;
    2283 1493 1494 1525 1524; 2284 1494 1495 1526 1525;
    2285 1496 1497 1528 1527; 2286 1497 1498 1529 1528;
    2287 1498 1499 1530 1529; 2288 1499 1500 1531 1530;
    2289 1500 1501 1532 1531; 2290 1501 1502 1533 1532;
    2291 1502 1503 1534 1533; 2292 1503 1504 1535 1534;
    2293 1504 1505 1536 1535; 2294 1505 1506 1537 1536;
    2295 1506 1507 1538 1537; 2296 1507 1508 1539 1538;
    2297 1508 1509 1540 1539; 2298 1509 1510 1541 1540;
    2299 1510 1511 1542 1541; 2300 1511 1512 1543 1542;
    2301 1512 1513 1544 1543; 2302 1513 1514 1545 1544;
    2303 1514 1515 1546 1545; 2304 1515 1516 1547 1546;
    2305 1516 1517 1548 1547; 2306 1517 1518 1549 1548;
    2307 1518 1519 1550 1549; 2308 1519 1520 1551 1550;
    2309 1520 1521 1552 1551; 2310 1521 1522 1553 1552;
    2311 1522 1523 1554 1553; 2312 1523 1524 1555 1554;
    2313 1524 1525 1556 1555; 2314 1525 1526 1557 1556;
    2315 1527 1528 1559 1558; 2316 1528 1529 1560 1559;
    2317 1529 1530 1561 1560; 2318 1530 1531 1562 1561;
    2319 1531 1532 1563 1562; 2320 1532 1533 1564 1563;
    2321 1533 1534 1565 1564; 2322 1534 1535 1566 1565;
    2323 1535 1536 1567 1566; 2324 1536 1537 1568 1567;
    2325 1537 1538 1569 1568; 2326 1538 1539 1570 1569;
    2327 1539 1540 1571 1570; 2328 1540 1541 1572 1571;
    2329 1541 1542 1573 1572; 2330 1542 1543 1574 1573;
    2331 1543 1544 1575 1574; 2332 1544 1545 1576 1575;
    2333 1545 1546 1577 1576; 2334 1546 1547 1578 1577;
    2335 1547 1548 1579 1578; 2336 1548 1549 1580 1579;
    2337 1549 1550 1581 1580; 2338 1550 1551 1582 1581;
    2339 1551 1552 1583 1582; 2340 1552 1553 1584 1583;
    2341 1553 1554 1585 1584; 2342 1554 1555 1586 1585;
    2343 1555 1556 1587 1586; 2344 1556 1557 1588 1587;
    2345 1558 1559 1590 1589; 2346 1559 1560 1591 1590;
    2347 1560 1561 1592 1591; 2348 1561 1562 1593 1592;
    2349 1562 1563 1594 1593; 2350 1563 1564 1595 1594;
    2351 1564 1565 1596 1595; 2352 1565 1566 1597 1596;
    2353 1566 1567 1598 1597; 2354 1567 1568 1599 1598;
    2355 1568 1569 1600 1599; 2356 1569 1570 1601 1600;
    2357 1570 1571 1602 1601; 2358 1571 1572 1603 1602;
    2359 1572 1573 1604 1603; 2360 1573 1574 1605 1604;
    2361 1574 1575 1606 1605; 2362 1575 1576 1607 1606;
    2363 1576 1577 1608 1607; 2364 1577 1578 1609 1608;
    2365 1578 1579 1610 1609; 2366 1579 1580 1611 1610;
    2367 1580 1581 1612 1611; 2368 1581 1582 1613 1612;
    2369 1582 1583 1614 1613; 2370 1583 1584 1615 1614;
    2371 1584 1585 1616 1615; 2372 1585 1586 1617 1616;
    2373 1586 1587 1618 1617; 2374 1587 1588 1619 1618;
    2375 1589 1590 1621 1620; 2376 1590 1591 1622 1621;
    2377 1591 1592 1623 1622; 2378 1592 1593 1624 1623;
    2379 1593 1594 1625 1624; 2380 1594 1595 1626 1625;
    2381 1595 1596 1627 1626; 2382 1596 1597 1628 1627;
    2383 1597 1598 1629 1628; 2384 1598 1599 1630 1629;
    2385 1599 1600 1631 1630; 2386 1600 1601 1632 1631;
    2387 1601 1602 1633 1632; 2388 1602 1603 1634 1633;
    2389 1603 1604 1635 1634; 2390 1604 1605 1636 1635;
    2391 1605 1606 1637 1636; 2392 1606 1607 1638 1637;
    2393 1607 1608 1639 1638; 2394 1608 1609 1640 1639;
    2395 1609 1610 1641 1640; 2396 1610 1611 1642 1641;
    2397 1611 1612 1643 1642; 2398 1612 1613 1644 1643;
    2399 1613 1614 1645 1644; 2400 1614 1615 1646 1645;
    2401 1615 1616 1647 1646; 2402 1616 1617 1648 1647;
    2403 1617 1618 1649 1648; 2404 1618 1619 1650 1649;
    2405 1620 1621 1652 1651; 2406 1621 1622 1653 1652;
    2407 1622 1623 1654 1653; 2408 1623 1624 1655 1654;
    2409 1624 1625 1656 1655; 2410 1625 1626 1657 1656;
    2411 1626 1627 1009 1657; 2412 1627 1628 1010 1009;
    2413 1628 1629 1011 1010; 2414 1629 1630 1012 1011;
    2415 1630 1631 1013 1012; 2416 1631 1632 1014 1013;
    2417 1632 1633 1015 1014; 2418 1633 1634 1016 1015;
    2419 1634 1635 1017 1016; 2420 1635 1636 1018 1017;
    2421 1636 1637 1019 1018; 2422 1637 1638 1020 1019;
    2423 1638 1639 1021 1020; 2424 1639 1640 1022 1021;
    2425 1640 1641 1023 1022; 2426 1641 1642 1024 1023;
    2427 1642 1643 1025 1024; 2428 1643 1644 1675 1025;
    2429 1644 1645 1676 1675; 2430 1645 1646 1677 1676;
    2431 1646 1647 1678 1677; 2432 1647 1648 1679 1678;
    2433 1648 1649 1680 1679; 2434 1649 1650 1681 1680;
    2435 1651 1652 1683 1682; 2436 1652 1653 1684 1683;
    2437 1653 1654 1685 1684; 2438 1654 1655 1686 1685;
    2439 1655 1656 1687 1686; 2440 1656 1657 1688 1687;
    2441 1657 1009 1689 1688; 2442 1009 1010 1690 1689;
    2443 1010 1011 1691 1690; 2444 1011 1012 1692 1691;
    2445 1012 1013 1693 1692; 2446 1013 1014 1694 1693;
    2447 1014 1015 1695 1694; 2448 1015 1016 1696 1695;
    2449 1016 1017 1697 1696; 2450 1017 1018 1698 1697;
    2451 1018 1019 1699 1698; 2452 1019 1020 1700 1699;
    2453 1020 1021 1701 1700; 2454 1021 1022 1702 1701;
    2455 1022 1023 1703 1702; 2456 1023 1024 1704 1703;
    2457 1024 1025 1705 1704; 2458 1025 1675 1706 1705;
    2459 1675 1676 1707 1706; 2460 1676 1677 1708 1707;
    2461 1677 1678 1709 1708; 2462 1678 1679 1710 1709;
    2463 1679 1680 1711 1710; 2464 1680 1681 1712 1711;
    2465 1682 1683 1714 1713; 2466 1683 1684 1715 1714;
    2467 1684 1685 1716 1715; 2468 1685 1686 1717 1716;
    2469 1686 1687 1718 1717; 2470 1687 1688 1719 1718;
    2471 1688 1689 1720 1719; 2472 1689 1690 1721 1720;
    2473 1690 1691 1722 1721; 2474 1691 1692 1723 1722;
    2475 1692 1693 1724 1723; 2476 1693 1694 1725 1724;
    2477 1694 1695 1726 1725; 2478 1695 1696 1727 1726;
    2479 1696 1697 1728 1727; 2480 1697 1698 1729 1728;
    2481 1698 1699 1730 1729; 2482 1699 1700 1731 1730;
    2483 1700 1701 1732 1731; 2484 1701 1702 1733 1732;
    2485 1702 1703 1734 1733; 2486 1703 1704 1735 1734;
    2487 1704 1705 1736 1735; 2488 1705 1706 1737 1736;
    2489 1706 1707 1738 1737; 2490 1707 1708 1739 1738;
    2491 1708 1709 1740 1739; 2492 1709 1710 1741 1740;
    2493 1710 1711 1742 1741; 2494 1711 1712 1743 1742;
    2495 1713 1714 1745 1744; 2496 1714 1715 1746 1745;
    2497 1715 1716 1747 1746; 2498 1716 1717 1748 1747;
    2499 1717 1718 1749 1748; 2500 1718 1719 1750 1749;
    2501 1719 1720 1751 1750; 2502 1720 1721 1752 1751;
    2503 1721 1722 1753 1752; 2504 1722 1723 1754 1753;
    2505 1723 1724 1755 1754; 2506 1724 1725 1756 1755;
    2507 1725 1726 1757 1756; 2508 1726 1727 1758 1757;
    2509 1727 1728 1759 1758; 2510 1728 1729 1760 1759;
    2511 1729 1730 1761 1760; 2512 1730 1731 1762 1761;
    2513 1731 1732 1763 1762; 2514 1732 1733 1764 1763;
    2515 1733 1734 1765 1764; 2516 1734 1735 1766 1765;
    2517 1735 1736 1767 1766; 2518 1736 1737 1768 1767;
    2519 1737 1738 1769 1768; 2520 1738 1739 1770 1769;
    2521 1739 1740 1771 1770; 2522 1740 1741 1772 1771;
    2523 1741 1742 1773 1772; 2524 1742 1743 1774 1773;
    2525 1744 1745 1776 1775; 2526 1745 1746 1777 1776;
    2527 1746 1747 1778 1777; 2528 1747 1748 1779 1778;
    2529 1748 1749 1780 1779; 2530 1749 1750 1781 1780;
    2531 1750 1751 1782 1781; 2532 1751 1752 1783 1782;
    2533 1752 1753 1784 1783; 2534 1753 1754 1785 1784;
    2535 1754 1755 1786 1785; 2536 1755 1756 1787 1786;
    2537 1756 1757 1788 1787; 2538 1757 1758 1789 1788;
    2539 1758 1759 1790 1789; 2540 1759 1760 1791 1790;
    2541 1760 1761 1792 1791; 2542 1761 1762 1793 1792;
    2543 1762 1763 1794 1793; 2544 1763 1764 1795 1794;
    2545 1764 1765 1796 1795; 2546 1765 1766 1797 1796;
    2547 1766 1767 1798 1797; 2548 1767 1768 1799 1798;
    2549 1768 1769 1800 1799; 2550 1769 1770 1801 1800;
    2551 1770 1771 1802 1801; 2552 1771 1772 1803 1802;
    2553 1772 1773 1804 1803; 2554 1773 1774 1805 1804;
    2555 1775 1776 1807 1806; 2556 1776 1777 1808 1807;
    2557 1777 1778 1809 1808; 2558 1778 1779 1810 1809;
    2559 1779 1780 1811 1810; 2560 1780 1781 1812 1811;
    2561 1781 1782 1813 1812; 2562 1782 1783 1814 1813;
    2563 1783 1784 1815 1814; 2564 1784 1785 1816 1815;
    2565 1785 1786 1817 1816; 2566 1786 1787 1818 1817;
    2567 1787 1788 1819 1818; 2568 1788 1789 1820 1819;
    2569 1789 1790 1821 1820; 2570 1790 1791 1822 1821;
    2571 1791 1792 1823 1822; 2572 1792 1793 1824 1823;
    2573 1793 1794 1825 1824; 2574 1794 1795 1826 1825;
    2575 1795 1796 1827 1826; 2576 1796 1797 1828 1827;
    2577 1797 1798 1829 1828; 2578 1798 1799 1830 1829;
    2579 1799 1800 1831 1830; 2580 1800 1801 1832 1831;
    2581 1801 1802 1833 1832; 2582 1802 1803 1834 1833;
    2583 1803 1804 1835 1834; 2584 1804 1805 1836 1835;
    2585 1806 1807 1838 1837; 2586 1807 1808 1839 1838;
    2587 1808 1809 1840 1839; 2588 1809 1810 1841 1840;
    2589 1810 1811 1842 1841; 2590 1811 1812 1843 1842;
    2591 1812 1813 1844 1843; 2592 1813 1814 1845 1844;
    2593 1814 1815 1846 1845; 2594 1815 1816 1847 1846;
    2595 1816 1817 1848 1847; 2596 1817 1818 1849 1848;
    2597 1818 1819 1850 1849; 2598 1819 1820 1851 1850;
    2599 1820 1821 1852 1851; 2600 1821 1822 1853 1852;
    2601 1822 1823 1854 1853; 2602 1823 1824 1855 1854;
    2603 1824 1825 1856 1855; 2604 1825 1826 1857 1856;
    2605 1826 1827 1858 1857; 2606 1827 1828 1859 1858;
    2607 1828 1829 1860 1859; 2608 1829 1830 1861 1860;
    2609 1830 1831 1862 1861; 2610 1831 1832 1863 1862;
    2611 1832 1833 1864 1863; 2612 1833 1834 1865 1864;
    2613 1834 1835 1866 1865; 2614 1835 1836 1867 1866;
    ELEMENT PROPERTY
    717 TO 719 721 722 735 TO 761 763 785 TO 787 791 792 795 TO 798 801 -
    802 TO 806 814 TO 816 821 TO 826 829 830 833 834 839 840 843 844 847 -
    848 TO 850 857 858 865 TO 872 882 TO 892 895 896 899 900 903 904 908 -
    919 TO 922 924 927 928 933 TO 936 939 940 943 TO 946 953 954 -
    957 TO 964 969 970 981 982 985 986 989 990 993 TO 996 999 1000 1003 -
    1004 1009 1010 1013 1014 1021 TO 1024 1030 TO 1034 1041 TO 1044 1405 -
    1406 TO 1421 1427 1428 1433 1437 TO 1439 1447 TO 1449 1454 -
    1459 TO 1480 1491 1502 1505 TO 1510 1515 TO 1524 1541 TO 1546 1549 -
    1550 TO 1558 1569 TO 1580 1584 1589 TO 1592 1597 TO 1606 1611 TO 1618 -
    1635 TO 1640 1644 TO 1646 1651 TO 1664 1677 TO 1682 1691 TO 1702 1719 -
    1720 TO 1722 1739 TO 1752 1755 TO 1760 1765 TO 1781 1783 1784 1789 -
    1790 TO 1800 1805 TO 1820 1829 TO 1832 1841 1842 1845 1846 1849 1850 -
    1855 TO 1872 1879 TO 1886 1895 TO 1902 1907 1908 1921 1922 -
    1931 TO 1938 1943 TO 1950 1953 1954 1961 TO 1968 1973 TO 1986 1993 -
    1994 TO 1996 2001 TO 2006 2009 TO 2012 2017 TO 2020 2031 2032 2035 -
    2036 2041 2042 2047 TO 2050 2057 TO 2059 2061 2062 2071 2072 2074 -
    2079 TO 2084 2087 2088 2093 TO 2100 2103 TO 2110 2113 TO 2122 2135 -
    2136 2145 TO 2148 2151 2152 2161 TO 2164 2179 2180 2185 2186 2191 -
    2192 TO 2202 2211 TO 2214 2217 TO 2220 2223 THICKNESS 0.0127
    2224 TO 2228 2231 2232 2237 TO 2614 THICKNESS 0.0127
    DEFINE MATERIAL START
    ISOTROPIC STEEL
    E 2.05e+008
    POISSON 0.3
    DENSITY 76.8195
    ALPHA 1.2e-005
    DAMP 0.03
    END DEFINE MATERIAL
    CONSTANTS
    MATERIAL STEEL ALL
    FINISH
    Cheers,
    Chris
