Bentley sisNET migration questions
Hello community,
I would like to address a few questions in regards to sisNET Application:
1. Is there a SaaS offering of the app?
2. If yes, is there a migration plan / support for it? Where could there be found the price list?
3. If not, what type of databases is the solution supporting?
4. If non-Oracle DBs are supported, is there any migration plan for it?
I found below information in the FAQ page, but I am not sure it applies to the application sisNET. Could you confirm?
https://communities.bentley.com/products/utility_network_analysis___design/w/utility_network_analysis_and_design_wiki/24091/faq
What are the database requirements for OpenUtilities?
Bentley OpenUtilities V8i (SELECTseries 4) can be implemented using number of different persistence models, including models that leverage Oracle and SQL Server databases.
What are the requirement for implementing OpenUtilities with SQL Server?
Bentley OpenUtilities V8i (SELECTseries 4) supports SQL Server 2008 R2, 2012, and 2014 databases.
Thank you in advance for your help!
Kind regards,
Tiberiu
