The Bentley Substation product team is pleased to announce the availability of Bentley Substation CONNECT Edition x64 (10.02.00.31) on Software Downloads.
If you would like the setup executable of Bentley Substation CONNECT Edition x64, please follow these steps to download it from Fulfillment Center:
Important installation requirements and notices are found in the Readme.
Please refer to the following link for the Resolved Issues in Bentley Substation CONNECT Edition. Also, be sure to visit the Promis.e forum on Bentley Communities to keep up to date with the latest information on Blogs, Wiki's, Announcements and Support Forums.
In previous versions of Substation, the Project Manager could not be loaded upon startup of the software. The standard Work Session Page tools had to be used to browse the file system to locate a DGN file of a project to open before the software could load the Project Manager which was not intuitive or convenient.
Now the Project Manager is displayed in the work session page immediately upon startup of the Substation application. This gives you immediate access to all the Project Manager features which enable you to quickly open Projects/Drawings and create new projects. Once a drawing is opened the ribbon menu is loaded so you can begin your work. You can return to the Project Manager by selecting the File menu in the ribbon menu at any time.
Substation placement tools now recognize the following formats when placing objects relative to a Digital Terrain Model (DTM):
Improved the speed and performance of the following commands:
CONNECT Licensing is Bentley's new process for product activation, enhancing our users' digital workflows and improving our licensing capabilities with features such as:
Traditionally, product activation has been through an activation key that an Organization distributed to all of its users. With CONNECT Licensing, product activation is managed by user sign in through the CONNECTION Client, which is installed on each machine that uses Bentley applications. This offers a more secure and manageable system as it offers usage alerts, notifying your users when they are about to reach a certain usage limit set by the Administrator.
