The Promis.e product team is pleased to announce the availability of Promis.e CONNECT Edition x64 (10.01.00.07) on Software Downloads.
If you would like the setup executable of Promis.e CONNECT Edition x64, please follow these steps to download it from Fulfillment Center:
Important installation requirements and notices are found in the Readme.
Please refer to the following link for the Resolved Issues in Promis.e CONNECT Edition Update 1. Also, be sure to visit the Promis.e forum on Bentley Communities to keep up to date with the latest information on Blogs, Wiki's, Announcements and Support Forums.
You can now window select or use <CTRL> and left click to select multiple symbol text attributes across multiple symbols and move all the text at once using the standard Move command. As an example, this is a convenient way to realign PLC function text where you want all the text across multiple symbols to align in a column.
This new user interface makes it easy to specify the catalogs you want the software to load and adjust their search order. The dialog can be accessed from either of these locations:
