Bentley Substation CONNECT Edition Update 3
The Bentley Substation product team is pleased to announce the availability of Bentley Substation CONNECT Edition x64 (10.03.00.42) on Software Downloads.
If you would like the setup executable of Bentley Substation CONNECT Edition x64, please follow these steps to download it from Fulfillment Center:
Important installation requirements and notices are found in the Readme.
Please refer to the following link for the Resolved Issues in Bentley Substation CONNECT Edition Update 3. Also, be sure to visit the Promis.e forum on Bentley Communities to keep up to date with the latest information on Blogs, Wiki's, Announcements and Support Forums.
The New Project Manager grants greater flexibility for managing projects by:
The Project Manager now features an updated Configuration Variables dialog that has separate tabs for updating both WorkSpace and WorkSet variables.
The Project Manager now gives you access to a Configure Database dialog which allows you to specify the default project database for any new projects that you create.
Migrating your projects from V8i to the CONNECT Edition is a simple two step process of:
A Configuration Assignment Utility has been provided with the CONNECT Edition making it fast and easy to associate your custom CONNECT configurations with your V8i projects. This tool is accessed from the Project Manager by selecting the Configuration Assignment Utility button.
ProjectWise integration has been extended to support managed WorkSpaces that allow you to now fully store your symbol catalogs inside of a ProjectWise repository. This helps to facilitate greater collaboration across your organization.
You have the added flexibility of being able to store your workspace configuration in a separate area of the ProjectWise repository from your projects so that an administrator can lock down the configuration while allowing users to create new projects as needed.
Quickly and easily group lightning masts to create 2D protection diagrams with calculation reports to ensure that substation equipment is properly protected from lightning strikes.
You can now window select or use <CTRL> and left click to select multiple symbol text attributes across multiple symbols and move all the text at once using the standard Move command. As an example, this is a convenient way to realign PLC function text where you want all the text across multiple symbols to align in a column.
The third party context menus that appear when you right click on any Substation object have been seamlessly integrated with the native power platform context menus, which has the following benefits:
