The Promis.e product team is pleased to announce the availability of Promis.e CONNECT Edition x64 (10.02.00.29) on Software Downloads.
If you would like the setup executable of Promis.e CONNECT Edition x64, please follow these steps to download it from Fulfillment Center:
Important installation requirements and notices are found in the Readme.
Please refer to the following link for the Resolved Issues in Promis.e CONNECT Edition Update 2. Also, be sure to visit the Promis.e forum on Bentley Communities to keep up to date with the latest information on Blogs, Wiki's, Announcements and Support Forums.
Components Center is a CONNECT service where Bentley publishes software content and users can upload their own custom content to be shared among all their users.
The Insert Symbol and Insert Cable features can query content found in Components center and insert the content into a design file by downloading the symbols to a local cache folder.
Several enhancements have been made to make inserting fields more flexible than ever before.
You now have the flexibility to specify even and odd wire numbering schemes when automatically assigning wire numbers to selected pages or circuits making it faster and easier to adhere to various electrical standards that require this type of numbering scheme.
The Symbol Creation Wizard has been adjusted to a more vertical layout and converted into a dock panel that enables you to dock the wizard in the drawing interface and collapse it to a tab if so desired.
You now have the option of including Installation, Location, and Device Tags in your Excel import files to specifically identify a device that the I/O addresses apply to. When these fields are specified in the import file, the software will only apply the I/O text to the device that matches the ID specified in your import file.
You now have the ability to right click in the Symbol Text dialog and remove an attribute associated with the selected symbol.
You now have the ability to turn on or off the visibility of Cable Diagram conductor text using a new display setting found in the View>Display menu.
