I have restored a project in Connect from V8i.
Are we able to replace its existing Project Options file with a new one that we want to apply to the Connect version of this project?
Jess
Hi Jessica,
Yes, you can replace Project Option File.
I tried to replace the project option.xml file from V8i to connect. I am able to work on this project in the connect.
I hope you are doing same steps as mine.
If there are any changes let me know.
Avanti Khandalkar
Thanks Avanti.
What were your steps to replace the project options file?
I want to compeltely change the Project Options file from one to another. (not manually update each option as i go)
Hi Jess,Ideally, you can change the project option .xml. All the project option settings get applied to the project as per the new setting. If you get any error please let me know.
Before doing this please take back of project options XML file.
Hi Jessica,For the restored Projects you can replace the ProjectOption.xml file with new ProjectOption.xml from. The restored Projects Project Option file is usually located in Project Folder. Regards,Satish Saptasagar
