Promis.e Insert macro
is there anyway to disable the device properties auto popup while inserting macros?
  • Hi Elango,
    We would like to update you that after you insert a Macro you will be present with a Device properties where you can specify device properties for the highlighted symbol which is part of the Macro and once you select Ok Promis.e will show the same dialog for next symbol in the Macro. This process will continue for all the Process in the Macro. You can skip specifying the Device Properties for all the symbols in the Macro by selecting the "Save & Exit" option in the Device Properties dialog which comes up right after placing the Macro.
    Hope the above suggestion helps with your concern!!
    Satish Saptasagar
  • Satish,
    I use to save&exit, but wondering to disable the feature itself on settings. Because we use to insert bunch of macros often.
    No Problem, thanks
