The OpenUtilities Substation product team is pleased to announce the availability of Open Utilities Substation CONNECT Edition x64 (10.09.01.20) on Software Downloads.
If you would like the setup executable of Bentley Substation CONNECT Edition x64, please follow these steps to download it from Fulfillment Center:
Important installation requirements and notices are found in the Readme file.
Please refer to the following link for the Resolved issues in OpenUtilities Substation CONNECT Edition Update 9 Refresh 1, 10.09.01.20. Also, be sure to visit the OpenUtilities forum on Bentley Communities to keep up to date with the latest information on Blogs, Wiki's, Announcements, and Support Forums.
New BOM Manager function called Insert Spare has been add to the right click menu. When this function is executed, the user will be prompted to enter the number of desired spares. After successful execution, new Balloon (Item) Numbers are added sequentially; starting at the active/selected record. Duplicates Balloon (Item) Numbers are not allow. When this condition is encountered, the user will be prompted to change the Number of Spares value.
Example Scenario: User needs to Reserve 5 Balloon (Item) Numbers starting at Balloon (Item) Number 13.
User Enters desired number of spares. (Example 5)
End result. 5 spare Balloon (Item) numbers are added. Note: By default, spare part numbers will appear in Bill of Material reports. Changes to your report template may be required if the autogenerated spare part number values do not need to be displayed in your report. (I.E. _SP1_, _SP2_ , etc.)
General Usability Improvements
