The Promis.e product team is pleased to announce the availability of Promis.e CONNECT Edition x64 (10.07.00.17) on Software Downloads.
Download
If you would like the setup executable of Promis.e CONNECT Edition x64, please follow these steps to download it from Fulfillment Center:
<br> <br>
Please refer to the following link for the Resolved issues in Promis.e CONNECT Update 7, 10.07.00.17 Also, be sure to visit the OpenUtilities Promis.e forum on Bentley Communities to keep up to date with the latest information on Blogs, Wiki's, Announcements, and Support Forums.
AutoBackup
The AutoBackup functionality has been improved to include Sub folders if desired.
When this option is enabled, all projects in any sub folders are subject to be automatically backed up based on the Project Selection option chosen.
BOM Manager Data Grid Sorting Improvements
User defined sort criteria is retaining throughout active the Promi.se Session. Restarting the application will reset sort criteria to above mentioned default.
BOM Manager Nameplate Improvements
Bill Of Material Balloon (Item) Number Reservation
Below BOM Manager function can be used to create spare line items on a Bill of Material report. New BOM Manager function called Insert Spare has been add to the right click menu. When this function is executed, the user will be prompted to enter the number of desired spares. After successful execution, new Balloon (Item) Numbers are added sequentially; starting at the active/selected record. Duplicates Balloon (Item) Numbers are not allow. When this condition is encountered, the user will be prompted to change the Number of Spares value.
Example Scenario: User needs to Reserve 5 Balloon (Item) Numbers starting at Balloon (Item) Number 13.
User Enters desired number of spares. (Example 5)
End result. 5 spare Balloon (Item) numbers are added. Note: By default, spare part numbers will appear in Bill of Material reports. Changes to your report template may be required if the autogenerated spare part number values do not need to be displayed in your report. (I.E. _SP1_, _SP2_ , etc.)
Balloon Placement supported for Panel Layout Drawings created with Saved Views / Reference files.
Panel Layout drawing techniques often involved using Saved Views and References from a 3D & 2Dmodels. Prior ballooning tool had limited capabilities for balloon placement. The new balloon function is now less restrictive.
Project Manager “Checked Out by” column (For ProjectWise integrated environments)
Users who have integrated Promis.e with ProjectWise now have ability to see checked out status within Project Manager.
General Usability Improvements
***Important Release Notes***
Parts Database Connect Update (Required for all SQL Parts Databases)
Parts Database Connection string for SQL Parts Databases will need to be updated. Parts Database connection strings are stored in PartsDBMappings.xml. This does not apply to users using a Microsoft Access Parts Database. Two methods are available to perform this update.
Method 1: Use the "Configure Database" option and select "Edit" to redefine the connection.
1. Select desired SQL Parts Database from pulldown.
2. Click Edit.
3. Click Next in "Edit Parts Database" dialog.
4. Click Finish in the "Edit Parts Database" dialog.
5. Click Close button in "Configure Parts Database" dialog.
6. Ensure your SQL Parts Database is selected by using the pulldown.
7. Click OK in "Configuration Variables" dialog.
8. Restart Promis.e. (If using a ProjectWise Managed Workspace, you may need to use ProjectWise Explorer to upload the updated version on PartsDBMappings.xml to your managed workspace.)
Method 2: Use Windows Notepad to edit the PartsDBMappings.xml.
1. Open PartsDBMappings.xml.
2. Replace all occurrences of Provider=sqloledb with Provider=sqlncli11.
3. Save PartsDBMappings.xml
4. Restart Promis.e.
