The OpenUtilities Substation product team is pleased to announce the availability of OpenUtilities Substation CONNECT Edition x64 (10.10.00.20) on Software Downloads.
If you would like the setup executable of Bentley Substation CONNECT Edition x64, please follow these steps to download it from Fulfillment Center:
<BR> <BR>
Important installation requirements and notices are found in Readme.
Please refer to the following link for the Resolved issues in OpenUtilities Substation CONNECT Edition Update 10, 10.10.00.20 Also, be sure to visit the OpenUtilities forum on Bentley Communities to keep up to date with the latest information on Blogs, Wiki's, Announcements, and Support Forums.
The following items summarize the new features and enhancements in the OpenUtilities Substation CONNECT Edition Update 10 release.
User is able to suppress display of same device connections for installation, location, and device tag attributes for wiring diagram destination strings. User is also capable of specifying a Jumper Connection Prefix or Suffix.
Add new configuration "Cross Reference Expression" to existing cable diagrams setting dialog. The expression is user definable. When user clicks the "Build Expressions" button, a configuration dialog opens allowing the user to configure a cross reference expression.
User is able to choose two merge types "Chamfer Merges" and "Filleted Merges" for cable diagram.
User is able to add their own levels, which will then be visible and possible to receive from the drop down list when inserting the cable / bus.
Submit validation to prevent submission of items when JSON Delivery Address is NULL or Blank.
