1. How to create a family for a multifunction Relay has more than one Module.
for example, SIEMENS (SIPROTEC-5) 7SA82.
It has 1 main module 2 separate modules with the same Product number. three Cross symbols, three wiring symbols. (Check attached pictures)
2. How to create a family for a product has 2 parent symbols.
hi G.G, you can create a compound family to achieve that. You can access from manage, and then create family.
Then, from "add" you can add cores (modules) with different parents.
Answer Verified By: Satish Saptasagar
Thanks Damian Pavon !
