It's possible to create my own VBA project and use CustemHooks
I have two questions:
1. I try to create new VBA Project in BUD which use  XfmStdUtilCustomization.ICustemHook just like x.p. XfmStdElecLib
When edit Configuration file and change "CustomPlacementLib" property on one feature to notify my project when proess this feature.
Unfortunately when I Place or edit this feature nothing is happened.
Any ideas why didn't worked?
2.  It is possible to implement  XfmStdUtilCustomization.ICustemHook in .Net AddIn?
Thanks.
  • Hi Nikolay,
    I'm not sure why only a single method would be called. GetFeaturePropertyHook is called whenever we access the configuration information, so it tends to be the first method called. Perhaps it is just erroring on this method before you get to the other calls?
    Mike
    This is a test
  • Hi Mike,
    I played some days with that how to add my custemhook instance in Singleton in .NET and I have success.
    In the beginning I tried to add my object in Singleton after the BUISMdlWrapper initialized. when I put my keyin command (CadInputQueue.SendKeyin "mdl load addintestapp" ) in Sub InitializeCustomPlacement()  in any of exiting VBA Projects everything  is work fine.
    The reason maybe is that Microstation try to execute  (vba run TestCustomPlacementCmds.InitializeCustomPlacement) but my instance is in .NET Addin.
    This is my output before I add  keyin command (CadInputQueue.SendKeyin "mdl load addintestapp" ) in Sub InitializeCustomPlacement()
    *************Added BEConn to Wrapper
    *************Added XFMAssociations to Wrapper
    vba run ElectricCustomPlacementCmds.InitializeCustomPlacement
    vba run GasCustomPlacementCmds.InitializeCustomPlacement
    vba run WaterCustomPlacementCmds.InitializeCustomPlacement
    vba run WasteWaterCustomPlacementCmds.InitializeCustomPlacement
    vba run CommonCustomPlacementCmds.InitializeCustomPlacement
    Failed to initialize the Customization Dictionary, Name = TestCustomPlacementCmds. No Custom behavior will be available during this session. The VBA projects and references may be invalid, or the CustomPlacementLibs setting in BentleyUtilityConfiguration.xml may be incorrect.
    InitializeBUISMdlWrapper
    And after:
    The string 3 is 3 as double.
    'UtilitiesDesigner.exe' (CLR v2.0.50727: DefaultDomain): Loaded 'C:\Program Files (x86)\Bentley\UtilitiesDesigner V8i\UtilitiesDesigner\mdlapps\addintestapp.dll'. Symbols loaded.
    Thanks.
