We use xml files created in the MA spreadsheet then generated by the GSA into .xml files for look up lists in the combo boxes on our placement and editing dialog boxes. We did this to make it easy to add or change values in these files (such as new street names etc..) are needed. However when we make a change in the xml file it is not being reflected in the dialog box. This is either when we edit or add a value. Is there a cache that needs to be cleared or another command that will re-read these domain .xml files?
Thad
