Importing shapefile into Bentley open utilities Designer V8i select series 4 issues
Can anybody help me in importing shapefile from GPS(Trimble Geo7x) to BOUD v8i select series 4 with the following issues:
1. Although it is being imported, the location of the points located in the same position.
2. Only one (1) point (point mapped to POLE) of the exported points can be seen in the display.
3. and when i try to export it to KMZ/KMl file, it will be located in some places which is not the actual location of the point.
Please help me with this issues..
thanks
Parents Reply Children
  • John,
    Since you have BOUD XFM project that defines a point feature class representing Pole data, you can use the "Feature Parameters > Mapped Name" = "Pole" as you've shown in the 2nd image. You can then also map the individual business properties of the SHP file to the Pole feature class using the "Property Parameters > Mapped Name" as also shown.
    To affect the imported size of the Pole cells, before running the Interoperability Import process, use the "Plot-Scale" pull down menu to select different scales. If those cell size changes are not sufficient, then a change using the Bentley Geospatial Administrator to the BOUD XFM schema may be required, adjusting the "Pole > Symbology > Cell X[YZ]Scale" settings.
    If mapping of the imported SHP data to an existing BOUD XFM feature class is not required, please note that you also have the ability to simply use the Interoperability Import "Cell Symbology" settings such as "Cell Library", "Cell Name" and "X[Y] Scale" to import the data.
    Jeff Bielefeld [Bentley]
