I am having problems where new text will disappear after editing, copying or rotating. The text will reappear once you save and close/reopen the design. Has anyone had the same problem and found a resolution?
Hi Erik,
I will need some additional information to provide you with the best answer on this inquiry.
Which OpenUtilities product are you using and what is the version number? Which tools are you using to create/place the text?
Please respond with the requested information and I will perform a quick test here and get back with you.
Kathy
Erik,
I am creating a Service Request to contact you directly. I will send you an email in just a moment.
This issue was previously reported and has been fixed. The fix is available in a new build of the software, which is currently undergoing our certification process.
In the meantime, the workaround is to Compress the design (via the File>Compress>Design menu option). This will prevent the user from having to close and re-open the design during their session.
You can find some additional information on the Compress Options here: https://communities.bentley.com/products/microstation/w/microstation__wiki/8368/compress-options
Kathy Wiggins
Technical Support
http://communities.bentley.com/
Answer Verified By: Kathy Wiggins
