design assistant
In building a structured design for electrical service is there any way to template the design or copy into another design ion design assistant ?
The design function is great as far as working with the existing drawing but I need to find way other than macros to build speed in design, especially if I am creating the same design structure at multiple different locations that are not connected.
  • Hi Mike,
    It is possible to copy placed features and assigned units, materials, etc. from an offline or template design into another design (or just drag and drop from one design to another). If you want to copy everything at a Work Location from a template into another design, you can use the Copy Assignments and Paste Assignments operations from the context menu on the Work Location.
    Is that the kind of function you were looking for?
    Mike
    This is a test
