I am having issues in BOUD when creating paths/spans. I try to initiate my first point of the path on an existing point (pole/transformer/etc.) and when I click my last point of the path and go to "Get Path" in Design Assistant, the system automatically creates a new point at the existing point. This causes a major error when trying to add conductor spans to the paths. Is there a set-in-stone insertion point for all symbols/points? Also, I hover my pointer over the existing symbol that I am using and wait for the pop up window that gives a description of the highlighted object to verify correct placement
Additional Info: The path/span creates a new point where it should recognize the existing point.
Hi Erik,
Is the existing point already a Work Location? So you get a P3 (for example) on top of the existing P1? If so, are they exactly coincident, or slightly offset from each other? Do both work locations show the same feature (pole/transformer/etc.) in the Design list?
Mike
