Hello all,
simply i try to add delete restrictions for specific features this is my code:
Public Function ICustomHook_PreDeleteHook(ByVal Context As String, _ oFeature As xft.IFeature, _ bCancel As Boolean, _ Message As String) As Long Debug.Print "xfmStdElecLib>XFMStdPlacementHooks.ICustomHook_PreDeleteHook" ' Set bCancel to true will stop feature action from happening ' if bCancel is true message will be displayed in the message center If oFeature.name = "BUDELEC_E_STREETLIGHTBANK" Or oFeature.name = "BUDELEC_E_STREETLIGHTUNIT" Then bCancel = True Message = "Unable to delete" End If End Function
every thing is fine but after i try to edit this feature BEConnectivity throw this exertions:
Also feature can't move.
Thanks.
Hi Nikolay,
I can reproduce this, and have created a defect for it. I will investigate if there is a workaround for this issue.
Mike
Thanks Mike!
