Hello all,
I use latest build on OpenUtilities 08.11.09.866 whit MSSQLServer and problem is there query some features the peer relationship is not return.
In OpenUtilities 08.11.09.705 it's work.
Thanks.
I wait 11 months to someone to answer issue.
I decided to decompile BUISOEventHandler assembly and seeing what happens there...
Be course I can't fix this in deployed assembly I create new addin whit functionality to query peer relations.
P. S. The IECNamed.Name is not same on IFeature.Name
Hi Nikolay,
Sorry that you didn't receive a response to this. If you ever have an issue that you need an immediate response to, please log a service request here: https://apps.bentley.com/srmanager/ProductSupport.
I've tried your case here, and I cannot reproduce the issue. Am I correct that your PS is saying that you are seeing a different IECInstance name from the expected?
Mike
Hi Mike,
I have service request for this issue and they give me some defect number but this is all.
Mike Carlisle said:I've tried your case here, and I cannot reproduce the issue. Am I correct that your PS is saying that you are seeing a different IECInstance name from the expected?
I using SQL Server 11 and IECNamed.Name return "BUDV8iSpatial_BUDELEC_E_POLE" and IFeature.Name return "BUDELEC_E_POLE"
for example.
Do I do something wrong whit configuration or register features?
