Bentley Open Utilities - Design Assistant.
When a point or span is created, a path is also created which contains folders inside. I know you can renumber the folders (work locations) inside the path, but is there a way to renumber the paths? It would be a lot easier and would make my design more organized.
  • Thank you for your post.  Currently there is no functionality to support this.  It is a good suggestion, though, and one we can add to our list of enhancements to consider.  Feel free to update this post with more on how it could be most usefully implemented, i.e.,
    would you only use numbers, or would it be practical to have the freedom to name them "Path A", "Path B", etc.?
    should the user always be prevented from repeating a path number, or should it be an option?
Reply
