I'm posting this question to determine the right process for referencing a DWG file from AutoCAD into BOUD. When checking the CAD file in AutoCAD the geocoordinates are correct. After getting in BOUD, I change the geographic coordinate system to the same one in the AutoCAD file, but the DWG does NOT come into the correct location. It is always scaled correctly and oriented proper (it's angled correctly - just not in the right X,Y location.) The same units and coordinate system/plane are being used so I don't understand why it gets brought into a separate location in BOUD. Is there a way to convert from DWG to DGN without losing the geocoordinates? What steps are involved in referencing the CAD file from AutoCAD into BOUD? Is there a step by step guide or manual floating around with the instructions on how to do this?
NH
